Calgo thru hull cable seals, NEED HELP!
Results 1 to 6 of 6
    Las Vegas, Nv
    Default Calgo thru hull cable seals, NEED HELP!
    I m trying to finnish up My calgo steering setup and need a little help with the thru hull cable seals. The seals that I bought to use are too smallfor the cable sheathing. My cables are 3/16" and the sheathing is exactly 7/16".
    here is my set up.
    This is the seal that I bought th use from the T/A plate to the adjustment bracket. The hole in this is exactly 7/16" and will not fit the sheath.
    This is an old seal, maybe even an electrical seal, which the hole is slightly bigger than 7/16". It does fit the sheath pretty good but slightly loose, but it it is but ugly!
    Here is a picture of Widowmakers setup and what I am trying to achive.
    Does any one know or have any ideas of what cable seals I can use to solve My delimma? I gues the stainless seals work well on the 1/8" cables that are common to the Calgo. I think they are for a size 33 seris cable. Need some help ASAP because this is the only thing holding Me up from completeing the steering.
ID:	81452   Click image for larger version.
ID:	81453   Click image for larger version.
ID:	81455   Click image for larger version.
    B1 Racing cs19's Avatar
    just get some new ones..
    They do the job and are cheap. Im a function guy and not a bling guy though.
    San Diego, CA
    Those cable seals are for the 33c cables. Rex Marine sells them. They are the 45 degree version. Here is the link.
    If you need different sized straight versions, go on mcmaster.com
    look under "cord grips" they sell the water tight versions in several different sizes and in aluminum too.
    The mcmaster part number i found is (8302K141) fits .38 to .50 o.d.
    they are about $11 each. Made of out aluminum.
    Boat 405.
    Las Vegas, Nv
    Yes I meant 33 seris. I originally ordered the 45* seals but they were back ordered with no idea of when they will get any just like my Tac is backordered with no Idea of an ETA, but that is another Rant! So i got the straight ones.
    Las Vegas, Nv
    Yea I wanted something that looked good ,but at this point I just want something that will work!
    Las Vegas, Nv
    So how do You get this seal over the meatal part of the 33c cable which is a little bigger than the plastic sheath?
    the metal part attached to the cable sheathing is larger than the sheath. am I missing somthing ? the seal is for 33c cable and the cable i have is supose to be 33c?
