Tricks for removing a 30 y/o grate
Results 1 to 12 of 12
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    Default Tricks for removing a 30 y/o grate
    With stainless phillips screws .... any tricks of the trade be for i strip them , and throw shiat How does an impact screwdriver work
    [/SIGPIC]
    before you even start i like to soak them in somekind of penetrant oil for a couple day before i even start. besure that you have a new driver bit that fits the screws heads tightly. and lastly be prepared to bore them out. good luck.
    Southwest corner AR
    An impact driver with a good tip fit to screw and a good size hammer! Turn the impact the direction to loosen while striking solid blows! If still in boat take your time because it will be flustrating! And as said lube them up good! WT
    WT
    WFL Crew!!!
    DJG
    DJG is offline
    Weld a nut to the head of the screw and the heat will help the screw back out. Then you can put a socket on the nut.
    Plan "A" Impact driver and Brass hammer Plan "B" Dewalt, protective goggles and carbide bits
    Senior Member UNASHAMED's Avatar
    Sep 2008
    Tucson, Az
    12 pack and a bfh
    "Don't make me get my penguin"
    Santa Clarita
    Floor jack, large screw driver with square shaft to accept a wrench, and a torch.
    Ukiah,Ca
    plan c-- drop off at toms... for a plate , set back and some shims ... Plan d - rob a bank
    [/SIGPIC]
    Ukiah,Ca
    torch er hole saw
    [/SIGPIC]
    San Diego, CA
    Quote Originally Posted by Lucky View Post
    Start with the impact screw driver, preferrably a fresh sharp one. It that doesn't work be prepared to drill it out. kinda pain but you'll never have to worry about it again. When you replace them use socket head screws so you can use an allen wrench to get them out and use plenty of anti seize and back them out a few turns or take the grate completely out of the boat over the winter. I usually loosen and apply antiseize every trip out mostly because I'm using black oxide steel bolts that rust but they are the strongest for my application.
    Boat 405.
    San Diego, CA
    done it works great.
    Boat 405.
    Ukiah,Ca
    thanks guys
    [/SIGPIC]
