pulling bellhousing off 3 point mount
Results 1 to 3 of 3
    Salem,Or
    Default pulling bellhousing off 3 point mount
    so is it possiable to pull off the bellhousing on my motor without having to completly pull my motor?...it looks like i should be able to unbolt the motor mounts so that i can lift it up a litte enough to slide it forward so the bellhousing and drivline comes off so that i can replace the ujoints in the drive line...and of course the starter would have to come off
    Should be fairly simple, support the back of the engine with the hoist, take the bolts out, lift a little and it should all come apart easily.
    you'll be almost as quick (and easier) to unbolt the motor , lift it up to eye level and then swap the DL that way simpler than working between the transon and rear of the engine Tom
