Installing engine
Results 1 to 8 of 8
Installing engine
    May 2010
    Default Installing engine
    I put the 460 in today hooked up the pump drive !!
    Where the Motor mounts bolt up the drive line is 1 1/2" high .
    It fit OK but is this to much?
    Wet
    Wet is offline
    East Hampton, CT
    Need pics to figure this one out.
    Wet
    Wet is offline
    East Hampton, CT
    Not good:
    Wet
    Wet is offline
    East Hampton, CT
    Perfect:
    May 2010
    Default Thats what it looks like!!
    The first photo is how its setting now..
    I guess I need to build brackets & set it down like photo #2...
    The other 2 boats are level, This sanger has a little small openning & I tried using mount I bought off EBAY..
    Wet
    Wet is offline
    East Hampton, CT
    I had to cut the rear plate about an inch to get it to line up. Remember, cut in small increments so you don't go under, and watch the pan clearance on your loader grate bolts.
    May 2010
    Default Got it going my way!!
    Took off the 4 angle brackets, set down where its LOOKING GOOD.
    Rebuilt them myself from 4x5x1/2 thick angle iron..
    Need 20" round aluminum tank about 36" long to use as fuel tank in front of engine??
    Only 2 seats!!! with a chrome spoiler up top between engine & seats..
    LOOKS fast as it is!!! Photos in 2 weeks when back from paint shop..
    Redding, CA
    Quote Originally Posted by pickleforksanger View Post
    Here you go. Pick one!
    http://www.appletreeauto.com/fuel-ta...-10-c-133.html
    I used the 10" X 33" 11 Gallon in the Hydro.
    Keep in mind if you get one of these, they only come with a single 1/4" bung in the bottom, which I kept as a drain hole.
    I had my local welder put in a #10 bung feed in bottom, #8 return in top, and a #6 vent in the top for like $40.00.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
