Delta pad tuning
Results 1 to 9 of 9
Delta pad tuning
    Cole SS cole ss's Avatar
    Rochester, wa.
    Default Delta pad tuning
    My 20' cole has a delta pad. Stock 454, 12jg, pd. What works best for ride plate angle? I have mine set at 2.5*. What are most people using for snoots, drop or straight? I am trying to get the most out of the boat without tearing into my reliable motor. Thanks
    Member Jet Hydro's Avatar
    lets see a pic of your delta pad bottom. What is your boat running now for mph and what do you have as far as motor and so on. With a stock 454 you`ll do best to see 60 to 65mph.
    Better to be an "Innovator" than a "Duplicator"
    Precision Speed & Marine
    Aggressor Jet Drives
    Rochester, wa.
    My boat runs 57 at 4500 with stock motor. I have a rebuilt pump, angle type loader, add a shoe and ride plate. I tried a AT drop snoot, it really did not do much for me. I was easier to porpose. Less easy to drive. I now have a 2* wedge on now.
    Rochester, wa.
    Anyone?
    SLOW MEMBER slowboy's Avatar
    Duluth, MN
    My boat used to have a delta bottom like yours until I made it a rounded keel.
    My old set up was with the ride plate around +2 degrees from keel, shoe 1/4 below keel, and the loader 3/8 above keel. I was running a droop and a six degree wedge, worked ok, porpoused a little at WOT. It ran 86-87 with a blown small block on pump gas.
    Best thing I ever did was to put the rounded keel on the bottom.
    Buy a better loader too.
    i'm back!! 1QuickCP's Avatar
    Montana
    well first off get a real loader, then the only thing i would do is add power. Ur runnin about the correct speed for 4500 rpm now, im guessin a "a" or 'aa" cut? I would look into a small blower kit like the weiand or b&m deal... probably run great with the exact same hardware if you were spinnin the pump 6000 ....
    Rochester, wa.
    What type of loader would you use with a stock motor? Did you wedge your drop 6* down? I am using a A impeller. I am just trying to get boat running as efficient as I can before adding HP. I would like to hit 60 before moving on to motor. Thanks
    LAID IN MEXICO
    santa paula, ca
    Default speed
    i know how to make that delta pad work for you. go to my profile and look at the pictures of mine. that should tell you exactly what that boat needs to haul ass.
    Rochester, wa.
    Very, very nice. Your boat has all the right stuff inside and out.
