Noobie Looking for A JB
Results 1 to 2 of 2
    Aug 2010
    Ontario Banada
    Default Noobie Looking for Jet Boat Recomendations
    Hey folks, great forum here!! The boats some of you have are amazing!!
    I live in Southwestern Ontario and will be boating in Lake Huron. I am looking for recomendations on a Jet boat. I am a Ford Big Block guy so that would be the power. Looking for hull and pump recomendations. Something under 25'. Will be used mostly for cruising and some fast shots.
    Thanks in advance for the advice!!
    Bill
    Jun 2010
    Michigan
    Hi Bill,
    I just bought my first jet boat a couple weeks ago. What I would do is spend some time and learn everything you can first about the boats, then look at lots of pictures and see if any style catches your eye. Once you figure out what you want then start looking all over the internet and see what is out there. I was looking for a jet boat for about 8 months until I found "The One"
    Word of advice.... Check out the boat stringers before you do anything as I ended up buying a boat with bad stringers and did not know because I did not do my homework before hand.
    Good luck and just my 2 cents here
