inner cooler plumbing
    Default inner cooler plumbing
    I'm putting BDS intercooler on my jetboat. What are the best ways to plumb it. Don't want to overpressure it and don't want to drill anymore holes than necessary.
    Douglas, MA
    personally I think its a water pick up on the bottom...into the intercooler and out into the pipes.
    That way you don't need a banderlog.
    SLOW MEMBER slowboy's Avatar
    Duluth, MN
    I put a "t" off of my pump line, with a ball valve to control the flow. Ran it into the cooler, then straight out the side of the boat with a larger size line. I put a pressure gauge in the outlet right off the intercooler so I can set the pressure easily. Seems to work good. I have heard of the way that TB recommended and think that that would work well too.
    Shell Knob, MO
    Sent PM.
    Duane HTP
