have you ever?
Results 1 to 10 of 10
have you ever?
    Feb 2010
    Default have you ever?
    Anyone ever sheared the bolts that hold the driveshaft onto the PTO? I have had my newly built boat out about 5 times 5th time out I was showing off a little racing some boats. Laid into it hit some waves soo I let off ( cause I was in the air :S) and then when I laid into it again bang!! sheared all 4 bolts into the Pto. They were grade 3 stainless bolts but I am also wondering if it has to do with my driveshaft angle. any ideas? I just got the old bolts out cleaned up the threads and got grade 8 bolts for it! try again I guess!
    The Right Coast/SE-PA
    No stainless used there on my ride> only 12-point grade 8
    Wet
    Wet is offline
    East Hampton, CT
    Quote Originally Posted by DSDANO View Post
    any ideas?
    Don't use stainless.
    Quote Originally Posted by Wet View Post
    Yup, too soft.
    Wet
    Wet is offline
    East Hampton, CT
    Your adapter/spacer is totally different than mine. My PTO is 4 allenhead countersunk, and then a 4 nut/bolt system.
    Feb 2010
    Thanks guys that has been the general concencus from everyone that saw what happened! I just know my driveshaft is on a good angle!! oh well I will fix that too!! Thanks guys
    Also be sure you torque them. If they worked loose that could have been the issue. Grade 8 and locktight.
    Feb 2010
    torque specs on them? and is red locktite ok?
    B1 Racing cs19's Avatar
    The bolts they supply with those PTO's are crap, I wouldnt run them on anything other than a stock engine.
    I used RED once = huge mistake at take apart time.
    Used Blue from then on.
    And torque was as tight as I could get them with a breaker bar.
