cleaning fuel tank help
Results 1 to 14 of 15
    Senior Member californiadreamin's Avatar
    Feb 2010
    Temecula CA
    Default cleaning fuel tank help
    ive got a bunch of junk in one of my tanks. theyre aluminum and glassed in. tried flushing with denatured alcohol but cant get the junk out. and i cant put fuel in the tank cause it seems to be ruining the gas. any suggestions? anybody know of something that can break the stuff down or a way to get it out?
    Put some diesel fuel in it and drive around town on the trailer. Let it sit a few days and do it again. Then drain it out. You'll be surprised how well it works at cleaning.
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
    i'm back!! 1QuickCP's Avatar
    Montana
    what kkind of junk? napa aluma brite...mix with some h2o...nasty stuff but will clean aluminium really well
    Wet
    Wet is offline
    East Hampton, CT
    Can you describe the junk, sir?
    Cas
    Cas is offline
    Angry American Cas's Avatar
    not sure what kind of junk you have in the tanks but my tanks had bad gas that had turned to varnish when I bought it. I used a couple of gallons of Acetone and 10 steel ball bearings per tank and towed the boat around for a few miles. I then pumped the tanks dry with an electric fuel pump and pulled the ball bearings out with a magnet, got the tanks real clean.
    For good measure, I also installed a fuel water separator from West Marine-
    and never had an issue.
    Feb 2010
    Temecula CA
    well theres some hard sediment that just sits at the bottom and some yellow goo stuff that looks like mold and seems to be stuck to the bottom of the tank. its just spots of it
    Feb 2010
    Temecula CA
    it kinda look like gas thats turned into jelly
    Feb 2009
    MANTECA
    Quote Originally Posted by DMOORE View Post
    Darrell.
    X2, I use it in the parts washing tank, and it works really good.
    Senior Member lbhsbz's Avatar
    Long Beach
    Go get a cheap drain snake, cut it so its about 10" longer than the distance from your filler to the back of the tanks, attach to drill, stick drain snake in tank, press button on drill. That'll break it up...now ya just gotta figure out how to get it out. Shop Vacs don't do so hot with gas soaked sediment...tend to turn into flaming shop vacs.
    Feb 2010
    Temecula CA
    ok so i did the diesel fuel. it helped some but this stuff is nasty. i need something thatll break it down. it wants to plug the pickup in the tank
    Wet
    Wet is offline
    East Hampton, CT
    Ever blow the lid off one?
    Those little clips don't hold very well under sudden pressure.
    Senior Member Uminchu's Avatar
    Apr 2009
    Lake Havasu
    Quote Originally Posted by californiadreamin View Post
    Since it looks like you have a lot of gunk, try fuel polishing. You can rent the systems. Do a Google search on it. Some friends have done this on their tanks with good results.
    West Mich
    Remove the tank if you can and have it steamed cleaned and pressure tested while its out .
    Sep 2009
    Winter Haven, Fla.
    Nitromethane is an extremely powerful industrial solvent too, kinda pricey cleaner, unless you could find some contaminated fuel someone was gonna dispose of anyway....
