Motor wont go over 3000 rpm!
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 45
    Wetnreckless805 Olds 455
    Mar 2010
    Paso Robles
    Default Motor wont go over 3000 rpm!
    I have a rebuilt olds 455, with a mild comp cam, edlebrock performer, edlebrock 1406 600cfm carb with electric choke and electronic ignition, out of the water the motor will rev out to 4 or 5k but in the water it stops pulling at about 3100 RPM. doesnt cut out or studder just wont accelerate past 3k...any ideas. I have full through on throttle linkage and timed it with a light...
    Senior Member GRoper's Avatar
    What impellar cut? What kind of gnition? Check that all plugs are fireing, boots are all the way on plug? I know, you have probably checked plugs, just goin through the check list in my head. Plugged fuel filter?
    Mar 2010
    Clarksville, TN
    What was it turnin before with the pump loaded??
    Wet
    Wet is offline
    East Hampton, CT
    Make sure the timing is advancing, and the secondaries are opening.
    your secondaries need load to open, no? Check those 1st.
    Wet
    Wet is offline
    East Hampton, CT
    Quote Originally Posted by SlowSquirt View Post
    Mechanical secondaries need a load? Anyhow, he stated that timing is good and full throttle is achieved
    Sep 2008
    Yuma, Az
    same thing happened to me. with no load, it would rev up to 6k no problem. on the water, it was maxxed at 4500 rpm's. turned out my secondaries wouldnt open. threw that carb away and picked up a 750 cfm holley and got it up to 5500 rpms on the water and 7k without a load.
    it could be a number of things, but that carb you have isn't help either.
    boatless....
    Sep 2008
    Yuma, Az
    Quote Originally Posted by Adam View Post
    I know nothing about edelbrock carbs "for a reason" but in his post he didn't say anything about the secondaries, are these carbs mechanical secondaries?
    i didnt either, till i googled it.
    Application:
    Street
    Edelbrock 1406 Performer 600 CFM Four Barrel CarburetorEdelbrock Performer Series carburetors have the ability to handle the demands of everyday driving and can still deliver the performance you want. It is unaffected by engine backfires because there are no power valves to blow out. The Edelbrock's 1406 uses metering rods to transition between circuits and these rods can be changed in seconds without removing the carburetor or draining any fuel. And once a Performer carburetor is tuned, it stays tuned. That means you get consistent performance. The lightweight two-piece aluminum body resists warping and is compatible with fuels that are blended. * Natural finish, order Edelbrock 14064 for EnduraShine finish.
    * Electric choke, square flange, non-EGR
    * For stud kit, order Edelbrock 8008 or Edelbrock 8024 kit
    Edelbrock 1406 600 CFM Four Barrel Carburetor• Designed for small block or small displacement big block engines
    • Match with Edelbrock Performer or Performer EPS intake manifolds
    • Includes both timed and full vacuum ports
    • Work well on stock or lightly modified engines
    • Calibrated 2% leaner than Edelbrock 1405 carbhttp://performanceparts.com/part.php?partID=468
    boatless....
    oldsmopile equipped
    Lake Lansing MI.
    Quote Originally Posted by YumaJet View Post
    Application:
    Street
    I would always go with a mechanical secondary carb with a boat, these are not cars. I also think 600 cfm is way to small for a boat, once again this is not a car.
    Menifee
    A couple points:
    Edelbrock carbs are great carburators, especially in a stick car. If you are parking your car and your emergency brake is non operational you can always shove that pile of shit carb under the front tire to keep the car from rolling. It works great and alot better than carrying around some old block of wood.
    Second point:
    You stated that the motor was rebuilt. Did you change the camshaft? If you did, do you rember how and where you installed it at? and please don't answer that question with "In my garage".
    It could be the cam is way out of timming. A friend of mine had a similar problem in his flatty. Wouldn't rev past 2600 rpm. After going through the carbs, dist, valve adjustment I figured out that it was a mechanical issue and not a tunning one. Tore it down and found the cam to be installed on the keyway and lined up with the crankshaft's dot (approx 116 degrees out)Re-Installed it the right way and it ran like a raped ape.....
    Keith...
    Quote Originally Posted by wetnreckless805 View Post
    my bad. didn't catch this the first time around.
    sand got it up to 5500 rpms on the water and 7k without a load.
    Why ?
    S CP
    A couple points:
    And they are shiney! I would borrow a carb and see if that is the problem before spending too much money.
    Senior Member jet460's Avatar
    Mar 2010
    Modesto, Ca.
    600cfm is too small for a boat with a 455.
    I have a 460 with 2 450's that tops out at 4700rpm's/60mph.
    Get a bigger carb.
