Dual valve spring cam break in
Results 1 to 14 of 23
    Sep 2009
    Calimesa CA
    Default Dual valve spring cam break in
    I have edelbrock performer aluminum heads on my 460. I have to break in a new comp cam and lifters (flat tappet). I have never done this before and the idea of removing the inner valve spring on every valve for the break in period is intimidating. I understand why it would be better to remove the inner valve spring. I am trying to justify breaking it in without removing the inner valve srpings. Any experience or guidance would be appreciated!!!
ID:	82322   Click image for larger version.
    Anaheim/BHC- the Shack
    One point I can bring up is GET THAT FRAM OFF THERE!
    Sep 2009
    Calimesa CA
    seeing as how that is near the begining of the tear down, the fram is not on there. any useable advice?
    Menifee
    Yes......remove the inner springs before you fire it. After cam break in re-install. My brother went through a couple cams at break in on a project he had. After removing the inner springs he never had the problem again.
    It's pretty easy if you have an air compressor.
    Keith...
    Sep 2009
    Calimesa CA
    I am guessing the compressor is to air up the cylinder to keep the valves in place when the springs are initially pulled?
    Senior Member GRoper's Avatar
    Wink
    Yes.
    Sep 2009
    Calimesa CA
    well common sense (which i am normally lacking!) is telling me to muscle through it and pull the springs for break in. damn!! thanks for all the help and anymore words of wisdom or means and methods would be greatly appreciated!!!
    The Right Coast/SE-PA
    Or...you can do as I do > bring cylinder up to TDC > fish in some stiff rope through the spark plug hole. If the valve drops it'll only drop about 1/8".
    Also >>> I see you're new here > multiple same topic posts are not permitted on the Forum. Please keep this in mind so future posts won't be deleted.
    I think there are a few guys who post here from the high desert area, maybe after this "big" weekend someone can help you. They might have one of the tools to help remove the retainer locks.
    I've done the rope in the cylinder trick on the river it works pretty good.
    S CP
    Menifee
    You'll need a valve spring compressor, an air valve to fit inside the spark plug hole and a rubber mallet. You can do it like Hammerdown suggested and not worry about the compressor and air valve. Both way swork fine.
    And Kudos to you for asking the questions first rather than flattening your cam and wondering how it happend...............
    Keith...
    okie, lake Texoma
    Take all the spark plugs out, remove the rockers from the cylinder that you'll be working on, stick a couple foot of soft cotton rope into the cylinder(leave a foot or so hanging out) and then rotate the engine over BY HAND until it smashes the rope up into the valves holding them in place while you use an over the stud valve spring removal tool. Then when you get the inners out of there and the keepers back in just turn the engine in the opposite direction about 90 degrees and pull the rope back out and move to the next cylinder.
    Same thing to reinstall
    H8-2-W8
    [email protected] first pass
    Senior Member River Dad's Avatar
    Riverside, CA
    Tried to convince a buddy to take the time on anew build and he didn't want to. Ate the first cam in 8 minutes from initial start up. The second time I told him and he still was convinced he just got a bad cam. Cam #2 took 13 minutes. After the second cam we had to tear down the whole motor because of all the shavings in the pan and bearings. Total pain in the ass and a complete waste of time.
    Take the time to do it right. I'm in Canyon Lake and I have all the tools you need and it takes about 30 minutes. You're welcome to them, or you can bring it down and I can help you. RD
    A number of stars need to be in alignment, when breaking in cams today. Reduced seat pressure is 1, proper oil with zinc additive 2, actual cam break-in process 1800 - 2000 rpm's for 20 minutes, and I mean 20 minutes at or between 1800 - 2000 rpm's, no if, and's, or but's. Key is getting enough oil flow on the cam / lifter for an established wear pattern.
    Senior Member sleekvino's Avatar
    go roller and forget it!!!
    PORNO RACING INC WHERE ITS "HARD" TO WIN
