Little Help
Results 1 to 12 of 12
Little Help
    Default Little Help
    I have a 19 cp with a 468 ,tunnel ram and two 750 carbs when i hit 5800 rpms it falls on its face and backs down to 5200 rpms. If i let of the throttle it will catch again but will only run up to around 5200 rpms. Any thoughts?
    Senior Member lbhsbz's Avatar
    Long Beach
    What do you have for a fuel pump?
    Is it an abrupt loss of power or a gradual drop down to 5200?
    Sep 2008
    OC, CA
    Probably fuel pump, also how big are your fuel lines.
    Senior Member zacho!'s Avatar
    tucson, Arizona
    have you tried changing jets?
    X's 3 fuel supply issues , check pressure and volume ..
    May 2010
    Pump is slipping on the hit, then catches up?
    Menifee
    Could also be the type of fuel line. If you have a good pump, you could be sucking the fuel line closed.
    Keith...
    Texas
    Quote Originally Posted by moppy View Post
    Most likely blowing the pump out on the start but soon as you get a little speed going to "load" the pump your rpm drops to where it should be. What kind of hp are you making and what cut impeller? That info would help alot. Is it just out of the hole it revs higher? If your at cruising speed and hammer the throttle does it go to 5200 or 5800? If your running out of fuel due to too small of pump or lines or whatever you will most likely get "lean pops" coming from the carb side, sounds like your ignition is taking a crap on ya, and if thats the case you better get it fixed becuase that will tear up a motor in a hurry. Also if your running lean, your motor will run hot, and your headers will be smoke'n hot!
    Nice!
    Wet
    Wet is offline
    East Hampton, CT
    Fuel floats too low?
    Brad
    The fuel preasure is at 7lbs. i would say it is a abrupt loss of rpms.
    Quote Originally Posted by Filucky View Post
    I am making somewhere around 600 hp. The boat runs hard out of the hole all the way up to 5800 rpm then it drops off to 5200. Also i didn't have this problem last year it would run up to 5800 rmp and stay there.
    No popping noise just a lost of rpms
    The fuel pressure stays at 7lbs what is the best way to check the volume?
