455 Olds help
Results 1 to 5 of 5
455 Olds help
    echo bay / las vegas
    Default 455 Olds help
    What drives the fuel pump on a 455 olds and where can i get one? thanks james
    There should be a stamped steel "eccentric" bolted to front of cam. Might be available from an Olds dealer. It is listed here at Dick Miller Racing about half way down page. Since it will require removal of timing cover to install, you will need TC gaskets and oil pan gasket. I'd suggest confirming it isn't installed by looking into pump mounting hole first.
    oldsmopile equipped
    Lake Lansing MI.
    Quote Originally Posted by echobayjames View Post
    the fuel pump "ecentrick" sorry very bad spelling, it bolts up in front of the cam gear, call some of the olds shops like rocket racing or olds performance products.
    oldsmopile equipped
    Lake Lansing MI.
    sorry oldsquirt beat my post
    ok thanks guys
