voltage help
Results 1 to 6 of 6
voltage help
    Cypress,CA
    Default voltage help
    I'm having voltage problems my volt gauge is only reading 12v. Should be reading higher I believe about what ? I have to date replaced the key switch, gauge and alternator what next ?
    May 2010
    have you taken a reading at the battery with a dvom to see what the actual voltage output is?should be around 13.8v to 14.6v. perhaps your having a gauge issue if your voltage is within spec when checkes at battery
    May 2010
    oops just noticed you replaced gauge.any way i will still check actual output at battery
    Quote Originally Posted by 74horizon View Post
    x2 and if alt is junk, pick up a 1 wire alt and be done with it
    Wet
    Wet is offline
    East Hampton, CT
    I was having some gauge problems this last weekend. The water temp was high, and the voltage was low...12v.
    As the day went on, and the hull got bounced, it became apparent that the terminal block I use under the dash was losing ground. I thought I was going to lose ignition as the volts never registered over 12. A little pressure to the wiring harness under the dash got the ground in check and the temp went to normal, and the volts showed 14.
    Cypress,CA
    Heard from a friend today it could be the optima batteries, have you ever heard of these batteries showing low voltage reading at idle. I have to try and bring the RPM's up and see if the voltage raises we will see.
