Bowl Stuffer
Results 1 to 2 of 2
Bowl Stuffer
    The Good mrjoshua's Avatar
    Aug 2010
    Albuquerque NM
    Default Bowl Stuffer
    What does a bowl stuffer do and would it really make much difference on a mostly stock 455 W/ a berk 12jc "A" impeller? Looking for ways to add performance w/o bigger hp.
    "Stuffer" refers to a "device" either "home grown" or manufactured that simply closes up the gap/space (clearance) between the dish area on the exit side of the impeller and the cooresponding void present in most bowls , Dominator and American turbine, Panther and some Jacuzzi impeller applications have a rear "wear ring" of sorts and a cooresponding area and surface cast/machined into the bowl that has to accept same this (a concept that has similar function to an added bowl stuffer) .
    Along with other mods and improvements the stuffer will help overall performance as an enhancement . but not something thats going to likley give you a "seat of pants" performance improvement however IMO. Adding significant horse power and jet "trim" will be the most noticables gain Tom
