81 bahner slow to start up?
Results 1 to 2 of 2
    Aug 2010
    Default 81 bahner slow to start up?
    just fired up the 460 ford after sitting for four years. very slow to start up. battery is brand new.
    Senior Member jet460's Avatar
    Mar 2010
    Modesto, Ca.
    Generally speaking, after 4 years you can bet the solenoid is rusty/bad, and the cables are toast.
    Maybe even the starter.
    Do basic voltage drop tests if you want to pinpoint.
    With a Ford, most of the time a slow start points to the solenoid or cable connections.
    Make sure you have a good connection from the key switch to the solenoid too.
    My $.02.
