impeller what size???? is it
Results 1 to 14 of 16
    Aug 2009
    Default impeller what size???? is it
    what is this an "a" or "aa" it measures 8.997 at its widest point from side to side...no marking[/IMG]s anywhere
    Aug 2009
    [/IMG]
    Maybe measure the large and small exit diameters and the blade angle ? hard to tell from the pic but looks like a AA
    B1 Racing cs19's Avatar
    Im going with A cut
    Aug 2009
    small exit diameter is 7.25 ,,,how would i measure blade angle??? mike
    A Protractor on the exit blade
    IMPELLER SIZE LARGE DIAMETER SMALL DIAMETER MACHINED ANGLE
    9 1/2" 9-1/2" 8-1/4" 25 DEGREES
    9 1/4" 9-1/4" 8-1/4" 20 DEGREES
    AA 9-3/32" 7-13/16" 25 DEGREES
    A 9" 7-1/4" 30 DEGREES
    B 8-3/4" 6-3/4" 33-1/2 DEGREES
    C 8-1/2" 6-1/2" 33-1/2 DEGREES
    Aug 2009
    thanks ,probably an "A"....5200 rpms is my max...my buddy has an aggressor "C" what kind of rpm change do ya think i would see with the aggressor????
    S CP
    Back into Boats Beal Motorsports's Avatar
    Dec 2009
    Kansas City
    Depending on the cut, aggressors chart shows changing from an A to a C should increase rpm by approx 700 rpm.
    Senior Member hotbo's Avatar
    lake Ouachita AR
    i would cut your impeller to a B cut,i would not run the C cut in this boat.
    i don't care what the aggressor charts say about sizing
    im with Chris looks A to me,need better pics
    WFLC
    2011 Performer SS
    built by Scott Seastrom.
    Dec 2009
    Kansas City
    Only 1 way to find out.....Cut it to a B and try it. If you need more rpm after that, cut some more.
    Has more to do with where his engine makes the best power.
    i'm back!! 1QuickCP's Avatar
    Montana
    Its a "a" if your measurements are correct.....if its aluminium I'd cut it to a "ab" or "b"
    Aug 2009
    anyone ever use a bowl shim to simulate a smaller cut impeller? i just had a feller offer me one .but ive never heard of this bowl shim that he speaks of????????????i think i like it though
    Atlanta, Texas, United States
    I don't buy that one.
