intake pressure tap location
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 44
    Aug 2009
    Default intake pressure tap location
    gonna do a pressure tap in the morning ....where should i put them? also is 1/4 the right size and where do i get that black plastic hydrolic tubing
    It's a sickness Eliminator#1's Avatar
    QC, Mcintyre
    1in from the wearing register, 5/32 plastic is what i use from parker store you can get everything you need there. here you go
    http://www.parkerstorephx.com/
    LIFE'S GOOOOOOOOD!!!!!!!!!!
    QE 072
    "BEER BUDGET RACING" Bodean's Hammer's Avatar
    Okmulgee, Oklahoma, United States
    I wanna get in on this, would an oil pressure gauge be ok to use? or is there a specific gauge that needs to be used? should the pressure be a constant # or will it fluctuate thoughout the RPM range?
    QC, Mcintyre
    Quote Originally Posted by Bodean's Hammer View Post
    oil gauge is ok
    QE 072
    i'm back!! 1QuickCP's Avatar
    Montana
    yup...I use autometer 0-100 psi oil...the big one. 1/8 pipe tap for me.
    On my cp19 about 30-40 psi WFO keeps her hooked pretty good...
    Mar 2010
    Clarksville, TN
    I put a autometer boost guage in mine
    After going through 2 other gauges over 15 yrs ago, I ended up purchasing an AuotMeter Liquid filled 2 5/8" boost gauge.
    The large face is easy to read, being liquid filled it doesn't bounce around and you can read it at speeds above 100 mph by just glancing at it. It's mounted up-side down so I can easily view it at speed. ( function over style)
    Even if you don't get the Autometer get a liquid filled gauge they are far easier to read.
    S CP
    Aug 2009
    im looking for and getting confused about where to put the tap hole on the suction housing some say left side some say right side,some say high some say low....argh....any theory would be helpful
    Basically 3 oclock or 9 oclock is fine. It will pick-up the middle psi, later on you can go high and low to balance the two. For starters 3 or 9 o'clock will give you something to work with.
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    1/8" pipe, 5/32 line. You can get everything at mcmastercar.com
    Impeachment! 75 TX's Avatar
    Culver City, Ca
    Thanks for posting the pic Shaun! Worth 1000 words. Looks like you tapped @ about 10oclock and 7oclock. Is that correct?
    Is it necessary to remove the pump from the boat to drill and tap? On my deal it looks like I could do it with the pump installed as long as I'm careful not to drill in too far and hit the inducer. Might not be the easiest task, but easier than pulling the pump and resealing afterward.
    San Clemente, Ca
    Quote Originally Posted by 75 TX View Post
    Is it necessary to remove the pump from the boat to drill and tap? On my deal it looks like I could do it with the pump installed as long as I'm careful not to drill in too far and hit the inducer. Might not be the easiest task, but easier than pulling the pump and reseasling afterward.
    Ya somthing like that, i think i was going for 1 and 5 (or 11 and 7 if you look at it the other way). When i was researching this everybody has their own spots they like to use.
    I did mine while the pump was in the boat, and i also have a inducer. What i did was pull the maint cover, stuff some shirts down in there up against the impeller to help stop any shavings. I rotated the shaft so that the inducer was at it's best position for not getting hit. Then carfully drilled, and tapped. Blew the shavings out the intake opening, removed the shirts and put back on the maint cover. Was a simple task actually.
    Culver City, Ca
    Nice. Thanks for the response.
    I think I read somewhere while searching that you were do some snoot vs droop testing. Am I correct? If so, how'd it go?
    San Clemente, Ca
    Yes, i found the snoot killed a ton of lift when cruising and actually made my boat ride like it did before all my upgrades (wet). When standing on the gas the snoot helped keep my boat in the water alittle bit longer but eventually the boat started to lift and jump out of the water. I also tried a stock nozzle adapter and i couldnt really tell the difference between the snoot and stock nozzle adapter. In the end i cut back the center strakes and now i have the droop on it again. Still not perfect, but made a huge difference.
