Torque Spec for drive line bolts
Results 1 to 3 of 3
    Las Vegas, Nv
    Default Torque Spec for drive line bolts
    Any one know what the driveline bolts(bolts from drive line to PTO) should be torqued to?
    Also when adding a PTO to the flex plate, does th torque spec of 60 ft lbs remain the same?
    Southwest corner AR
    Hal, I just pull them down tight as possible! They are not easy to get on so make sure they are tight and I use locktight too! WT
    WT
    WFL Crew!!!
    Sep 2008
    Yuma, Az
    i tight them up good and have never had one back up a bit. while doing new things to my motor over the last few months, the driveline comes off a few times a month. your doing a setback right hol?, if so, i would say no to locktight.
    boatless....
