Comp marine cams?
Results 1 to 11 of 11
Comp marine cams?
    Senior Member Sharkbit's Avatar
    Jan 2010
    Default Comp marine cams?
    are these a good choice for jets? I have a mostly stock 454 in a 20ft cruiser. It does have intake, 850 dp, hei. Berk split bowl and droop. I know this boat will never be fast but....currently runs 55 at 4200rpm.
    I've figured out the fuel pump lobe is flat on the cam so I got to thinking about what shape the other lobes would be in. I was looking at this
    CL11-236-4 - Comp Cams 'Xtreme Marine' Hydraulic Flat Tappet Camshafts Details
    Chevy 396-454ci Big Block 1965-96
    *Note: In order to use these camshafts in 1965-66 396/427ci blocks, it is necessary to machine a 3/16'' wide x 7/64'' deep groove in the rear main journal of the cam to allow oil flow to the top of the engine. Jet with ''A'' impeller, strong mid-range good throttle response, noticeable idle.
    Operating Range:1600-5800 RPMDuration Advertised:270° Intake / 286° ExhaustDuration @ .050'' Lift:226° Intake / 236° ExhaustValve Lift w/1.7 Rockers:.544'' Intake / .547'' ExhaustLobe Separation Angle:112°
    Jan 2010
    I wanted to keep it reliable as ever just maybe pick up a little power. This will be a winter project along with a pump rebuild and interior. $$$$$$$
    California
    In a mostly stock engine(assuming 8:1 ish compression), you'll be better off with the 11-232-3, the next step down from the cam you listed.
    Aug 2009
    O.C. & Lost Lake
    Are you sure the lobe is gone and not a wore down pushrod?
    Dallas, TX
    He just doesn't want to be shown up by 25' of Pimpness. The flat pump lobe is just an excuse for him to do a cam swap.
    In all seriousness he may be right about the lobe being flat. Several of us looked at it on several occasions at the beginning of summer. We all came to the same conclusion.
    Member RUFF IDLE's Avatar
    Riverside, California " Woodcrest "
    Exclamation
    Yiu may already be aware,Be sure to use motor oil that is compatible with a flat tappit cam or the new cam won't last long.
    My garage is BIGGER than my house, NO PROBLEM ! Any questions?
    Senior Member speedealer's Avatar
    Albuquerque,N.M.
    have a 21 sleek 482 9:1 comp,small port o49 castings with 225 /188 valves,team G intake 850. We boat at 4500ft and higher. we run solid rollers with 230 to 245 and mid .600 lift, we also tighten lobe centers to 106. really helps at altitude,does this hold true for lower altitudes. Boat runs 67mph on gps.
    Ran one of these for years......
    Comp Cams High Energy 280AH hydraulic Marine camshaft for Chevrolet BB 396-427-454. Jet boat with A impeller. Skiing, pleasure use, & performance.
    Specs are as follows: 280/288 Advertised Duration
    Duration @ .050" 232/237
    Valve lift .547/.547 with 1.7 rocker ratio
    Lobe seperation angle 110 degrees
    RPM operating range 2400-6400
    Sep 2009
    Red Mountain, Az
    So how did you like it...hydraulic lifters or solid
    Jan 2010
    Good point! It does have flat tops so 8:1 sounds right. A baby cam would prolly be better.
    Jan 2010
    Don't make me sneak up and steal your drain plug!
