Anybody use MSD pro billet dist on Tunnel Ram Olds?
Results 1 to 14 of 15
    27T
    27T is offline
    Jul 2009
    Default Anybody use MSD pro billet dist on Tunnel Ram Olds?
    I'm swaping my points dist. for MSD pro billet on my 455 Olds w/Tunnel Ram. Anybody done this before and no what combo of springs give proper timing advance curve? or any advice on initial and total timing?
    THANKS!
    -Nick
    Kingman/Golden Vly, Az
    not to change the subject, but, what make is the manifold?...what make are the carbs & what cfm?
    TIA
    FastRat
    Nov 2008
    Fuquay-Varina, NC
    I just did the same swap on my 460 this spring, best upgrade to the boat ever, you'll love it.
    '77 Caribbean
    27T
    27T is offline
    Jul 2009
    TIA
    FastRat
    Offenhauser, Holley's carbs, I was told there 650s, but I dont know for sure....
    27T
    27T is offline
    Jul 2009
    Quote Originally Posted by Storz View Post
    do you run tunnel ram on your 460? what do you run for timimg?
    Nov 2008
    Fuquay-Varina, NC
    Quote Originally Posted by 27T View Post
    Yeah it has a Weiand tunnel ram, running a total of 36* of timing, have the 25* spacer set up in the dizzy, with 11* initial and the softest springs so the timing is all in by like 2500 RPM or so.
    That being said an Olds motor may require different settings, I'd give Tom at JBP a call and I am sure he can point you in the right direction.
    '77 Caribbean
    Lake Havasu az.
    I run a stock 455 wit 2 660's on a weiand t/r and an HEI....It's v-drive with a lot of gear, so i need a low idle for no wake zones....I run total timing @38* with a 50/50 pump gas mix...it will make a little more power at 43* on straight 91 octane. It will run best locked out @38 but it will do that timing stall thing that is hard on starters.
    It will idle @1k in neutral and 800 in gear on both carbs and 650 on one carb..last trip out i put a cleaver prop on...seemed to hook better than my last prop and got some guff over my no wake speed...it will idle @600 with no problems.
    With your deal..if you are running stock compression i.e. 10-1...lock it out and try it at 36* and see where that gets you...'curve is for cars' olds will give best idle and response with the most base timing you can run.
    BTW..don't know how big the msd dizzy is but hei doesn't exactly fit...
    had to grind a little off the manifold on the back and file the hold downs on the cap a little.....seems stock hei is more that enough
    dizzy....autolite plugs @.045 and taylor wires...never had a problem
    Sheriff Joe Arpaio
    with your ol lady
    Pretty sure the HEI wont fit with the tunnel ram on an Olds. I know it wont fit on my SBO/BBO set up.
    No more Mr. Nice Guy !
    27T
    27T is offline
    Jul 2009
    Thanks for the info! the MSD is about the same size as the points dist., so it will fit. right now the boat wont idle(or stay running) under 1000rpm
    Tim
    Tim is offline
    Senior Member Tim's Avatar
    Hangtown, Ca
    I run the smallest bushing and the lightest springs with about 10 deg initial and shoot for 36 total. Check R.O.P. for the correct measurements on the balancer to check for total timing.
    Member phil369's Avatar
    N W Ga.
    Running offy t-ram with 2 650s, msd & locked at 36* on pump gas, no probs in 12 years.
    Member E Rock's Avatar
    Jun 2010
    Tulsa OK
    I'd love to have a tunnel ram for my olds, if any of you dudes have an extra manifold or know where one is, get ahold of me!
    That way I can contribute to this thread
    oldsmopile equipped
    Lake Lansing MI.
    Quote Originally Posted by slam View Post
    I think there is still one for sale on real olds power.
    Jun 2010
    Tulsa OK
    Are you talking about the single carb one in Arizona? It sold l.. I'm really looking for a dual.. There is a single here in the parts spam too, I guess I'm being picky... Beggars can't be choosers
