Well crap....
Results 1 to 14 of 15
Well crap....
    Nov 2008
    Fuquay-Varina, NC
    Default Well crap....
    Got all the bits and pieces yesterday to complete the exhaust swap. Spent a little bit of time installing the flappers in the 4" tips, and finally mounted them into the transom. Installed the 3" to 4" bellow adapter on the tips and grabbed the new 3" soft wall hose I had ordered and tried connecting the snails to the tips and the angle is just to great for the hose to flex I really though the soft wall stuff would have more give than it does.
    Not really sure what I am going to do now, thinking of taking it to a custom exhaust shop and seeing if they can bend a piece of 3" pipe to fit between the snail and tip, and then use pieces of that 3" soft wall hose to connect them together.
    Any ideas?
    '77 Caribbean
    Member hollbrow's Avatar
    South Ga.
    Default Sometimes
    You may have to buy/make an adapter that will flange onto the snails and turn down a bit. Want to keep that flex hose straight if possible. I had to cut off the end and weld a short section of 4" tubing onto my thru hull bassetts to drop down a few degrees so I could use some existing holes in my transom for my tips.
    Jul 2009
    Hesperia California
    I want to do the same thing, sure would like to see some pics when you get her done. just tired of the noise... maybe I'm getting OLD
    oldsmopile equipped
    Lake Lansing MI.
    use a wedge, I think cp performance sells them, I will dig up a pic from another site of some home made ones.
    oldsmopile equipped
    Lake Lansing MI.
    oldsmopile equipped
    Lake Lansing MI.
    that's old guys pic, just using it to show ya, hope it helps.
    Nov 2008
    Fuquay-Varina, NC
    Quote Originally Posted by hollbrow View Post
    Got any pictures of your set up?
    '77 Caribbean
    Massachusetts
    Are you saying that the geometry is off even if you manage to connect it? If it looks like it does line up - You can bend the hell out of that rubber exhaust. If you push or pull on it hard it will collapse and then it bends easier, don't worry about hurting it, it will open back to it's original shape. Begin with it hooked to the transom tips, then jack-knife fold it onto the riser.
    Real Boats Don't Have Propellers!
    -- Rivernut
    Nov 2008
    Fuquay-Varina, NC
    Just got off the phone with a local exhaust shop that does lots of custom work (they did the whole exhaust on my BMW) and I am going to take the boat up there Friday morning to have them make an S pipe for me.
    '77 Caribbean
    Southwest corner AR
    Need pics. to see what your problem is!
    Short pieces of the hose are hard to get on! I had to remove the tips on my Taylor to get the hose to connect! Then reinstall the tips!
    I didn't have 3"risers going to 4"tips so the adapter is taking up hose length thus causing no hose bendy! WT
    WT
    WFL Crew!!!
    Glendale Arizona
    I swapped out a set of logs for some TT Bassetts for a friend of mine and had to do em the same way.
    Flex my ass.
    P.S. I was not responsible for the cable routing.
    Douglas, MA
    Flex my ass.
    you just made me feel a little better about the cable routing that I just had done to mine...damn loop goes like 2 feet in the air.
    Glendale Arizona
    Again..........not responsible for cable routing. The friend that owned it didn't do it either. He bought it that way.
    Damned shame. Rogers 19 Bonneville. Went through and fixed a bunch of little things for him (he's not mechanical). It wasn't perfect and still needed some cosmetic work, but it ran great. He ran it for a year and then it's sat uncovered in his back yard for 10+ years. Completely ruined it.
    I don't feel tardy Hallett Dave's Avatar
    Lancaster
    I HATE TO SEE THIS KIND OF SHIT HAPPEN.
    Im non induced and My turd leaves pretty hard as she sits.
