stringer rail engine mounts????
Results 1 to 12 of 12
    Senior Member badbug3's Avatar
    Default stringer rail engine mounts????
    I always wanted to know the answer to this. Why is it that most all engine rail mounting is done with the rails bolted to the side of the stringers where all the load is placed on the bolts going through holes in the stringers???
    Seems like to me the best way would be to just lay the rails on top of the stringers and then through bolt them through the stringers and then most of the load is taken away from the bolts and the holes going through the stringers??? Also should stop the wearing out of the holes in the wood stringers!!!!!!!!
    Whats the deal with this???!!!!!!!!
    Senior Member lbhsbz's Avatar
    Long Beach
    Ideally, there should be no load on the bolt holes in the stringers...especially when you put a plate on the outside of the stringer instead of just stringer washers. The bolts are loaded in tension and should simply clamp the rails to the stringers. The clamping force should take all the load...and would if the stringers were not made of wood and were compressable. Most of the wear you see is most likely due to a decrease in the bolt tension over time due to the stringer compressing....need to check and retighten the rail bolts more often or add a plate to distribute the clamping force better over the entire stringer.
    If the wood stays dry, and the glass does not delam, there is little issue. Seems somewhat common for the flat bottoms to have their rails over the stringer, just not done on jets for what ever.
    Kingman/Golden Vly, Az
    Quote Originally Posted by badbug3 View Post
    this is exactly the way my rail set-up is on the boat i'm slowly/surely building...they set on top of the stringers & a flat plate on the other side...the front & rear motor mount plates set on top of the rails with feet to the rails...i was lucky & found plates that would allow me to do this ...sometimes, if you cant find the right width plates, you have to opt for a different route to take...i think it is alot stronger set-up
    FastRat
    WFL Crew TINTDESIGNZ's Avatar
    East Texas
    I ordered my rail kit new from JBP and as you can see it has stringer plates for the outside of the stringer. Even with 1" stringers it is plenty strong!
    WFL CREW!
    http://www.performanceboats.com/cont...-magazine.html
    Everybody wants some...I want some too!
    Long Beach
    Quote Originally Posted by TINTDESIGNZ View Post
    What diameter bolts does that setup use to hold the plates to the blocks?
    East Texas
    3/8 i think.I went back and put purple stringer washers just for a little more bling. oh-you said blocks sorry.
    WFL CREW!
    Redding, CA
    I have wanted to put rails in the Miller for a while now, but the stringers are very narrow.
    I think they would have to go over the stringers, or bolt to the outside?
    Otherwise it looks like top mount starter and a bunch more expense?
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Senior Member Mike D's Avatar
    Anaheim/Aha
    here is one over the rails
    Impeachment! 75 TX's Avatar
    Culver City, Ca
    The stringers themselves are narrow? Or the two stringers are close together?
    Here's how Jack setup my old Miller. No top mount starter, but I did use a Powermaster mini.
    The new (to me) boat's stringers are farther apart, necessitating new front and rear engine plates. Still have the ones from the Miller though.
    Tommy the plates can be "knotched" and let to run wild over the tops of the stringers (1rst pic) or the motor plates can be custom cut (and edges polished)for specific stringer width's The rails simply need to be relieved for low mount starters Tom
    heres a few various recent installs including a Miller similar to yours
    Redding, CA
    Thanks TX and Tom.
    Tom, I'll probably want to have You and Josh do something this winter along these lines!
    Tommy
