my gripe of the day
Results 1 to 14 of 20
my gripe of the day
    Charlotte, NC.
    Default my gripe of the day
    OK so this weekend had its ups and downs but something came to my attention..
    WTF is this rudder for... unless im giving it gas that thing is useless..... its redefines the word useless...
    I almost introduced mr dock to mr boat this weekend....
    So Cal
    if you're moving ... and I say if ... it might help a little, but just a little ...
    give us the story, I'm sure we can all relate
    Most peeps have those rudders on a shelf in the garage
    Senior Member snake321's Avatar
    Middletown, Connecticut, United States
    Only helps in a no wake zone when your going 1 mph..
    YOU LIE!!!!!!!!!!!
    Quote Originally Posted by Ultra26 # 1 View Post
    I've been known to be a jackass a time or two.
    Glendale Arizona
    That's where mine is. In a box labeled useless jet parts.
    Senior Member TrollerDave's Avatar
    Chino,CA
    Weld 2 feet of flat stock to the bottom of it ...
    then you might notice a difference.
    Cas
    Cas is offline
    Angry American Cas's Avatar
    you could always mount it to a helmet to help with turning.....
    El Cajon, CA.
    It's just there so when you're not giving it gas it will turn (hopefully). The jet drive is what makes it turn when you're giving it gas. The rudder has another usefull aspect to it, it bottoms out before anything else on the back of the boat when you're going into and out of steep driveways. Think of it as a useless skidplate.
    yep, throw it in the corner of your shop and forget about it, they're useless unless you build a huge 1 that creates a ton of drag.
    Monroe, WA
    Red face
    Same gripe here! I took the new boat out to the river Saturday and the idle was set really low so it quit the first few times I lifted off the throttle. Of course this was at almost full speed in a turn heading for a bridge. I tell ya that rudder did absolutly nothing!!! I had it hard over and she shut down straight as an arrow. Luckily it finally dropped down to a stop with around 30 feet to go, but my eyes were wide open for a few seconds.
    Oh yeah, it's comin' off!
    Malcolm
    75 Spectra 18
    77 Spectra 19 project
    plano texas
    i have on for those supper sonic speeds.
    Cas
    Cas is offline
    the one thing about the rudder is it's also supposed to help prevent the boat from spinning out. Since I've never run one, I don't even know if that's true either.
    I do know that a couple of years ago, someone at one of our outings had the bolt break. When that happened, his boat wanted to steer every which way except the way he wanted it to go.
    Charlotte, NC.
    this would have done me more good.. engine cut off as idle was too low and wheel hard right and nothing.. luckily the wife was on the dock and helped me avoid any damage...
    Delemorte,
    It depends on the boat. I put one on my 18ft CP and and never knew when it broke off virtually no difference. They were the cheap plastic ones and they broke first time out, twice.
    My 21ft carrera bow rider when it loses one it becomes real squirrelly (like when you the diverter to high) at almost any speed and is a lot harder to put on the trailer.
    The other good thing is they are a nice warning system when you hit bottom (not before). On the 2 boats I have had one on, they both responded completly opposite. Also at idle or with the motor off they do next to nothing.
