Cost of a longer driveline?
Results 1 to 9 of 9
    Las Vegas, Nv
    Default Cost of a longer driveline?
    Does anyone know roughly what it cost to have a longer driveline made?
    Feb 2009
    MANTECA
    120 for a pipe with two ends welded and balanced, but that was a couple of years ago.
    Had Johnray at "BIG A PERFORANCE" build a new one for me last year, and was exact to my spec.
    My local guy screwed my last one up, cut it .750 too short for a jet-way, and nailed me $275
    Senior Member CP598's Avatar
    Sep 2008
    I just had one made, and it was $500. I did some checking around, and was quoted anywhere from about $385 on up depending on whether it was the 1310 or 1350 series, length, tube diameter etc.
    a friend priced a 1310 recently about $150 using spicer ends
    this was for the center section only
    #55
    Hal, call Adams Driveshaft 568-5680 James near Sunset and boulder highway. He did me great on my daughter's shaft. Way cheaper and better. Pat
    Recently had a new longer D/L to replace my previous ,made by the folks that build my 1310's , they made the barrel from larger OD heavy wall tubing ,nicely welded balanced ,new Spicer ujoints and spline yoke
    WFL Crew TINTDESIGNZ's Avatar
    East Texas
    Bought mine from Tom at JBP. Don't remember how much but it was reasonable and it fits nice.
    WFL CREW!
    http://www.performanceboats.com/cont...-magazine.html
    Everybody wants some...I want some too!
    Kingman/Golden Vly, Az
    just get an old drive shaft the dia you want & measure the length you need & cut off your ends & take it to a drive shaft shop & have them weld it up...easy! ...just sayin' my .02 cents
    FastRat
