couple questions on drive line and clearance.
Results 1 to 6 of 6
    Las Vegas, Nv
    Default couple questions on drive line and clearance.
    I put a digital level on the pump intake flange and zeroed it and then put the level on the carb mounting flange and i have 1* difference. Is this ok?
    Also at the drive line and the pumpbrace I have a 1/2" clearance. is this Ok or is it to close for comfort?
    Here are a couple of pics of the DL does it look too straight or does it look ok?
ID:	83520   Click image for larger version.
ID:	83521   Click image for larger version.
ID:	83522   Click image for larger version.
    Aug 2009
    i stole it fer sure somn blakk paint gets rid of thatt rust silly goose......blakk paint eats rust ya no
    Las Vegas, Nv
    Yea it will get fixed up in a minute. Still have to replace ujoints. Just mocking up right now.....H
    Hal it looks fine to me, 1/2" is enough clearance IMO
    remember you need 1/8 to 1/4 inch end clearance also
    #55
    Southwest corner AR
    Pull two ujoint keepers off the caps on the two parts that go the crank and the one that goes to the pump. Turn the joint up and take a stright edge and two nuts put the nuts where the keepers would go and use the stright edge across the two nuts! As long as it is level not cocked you are good to go! Now turn the joints 90* to the side and check alignment again if level there run the piss out of it! You can be a little off cause you don't want 0* needs a little offset for joint movement! WT
    Your setup looks real good and close!
    WT
    WFL Crew!!!
    Default Reference points
    Your set up looks fine. However, the top of the intake leaves a lot to be desired as a reference point. Crank centerline, and intake mounting surface are not necessarily parallel. A better reference point is a magnetically mounted indicator off the crank flange to the pump shaft. The pump shaft and the crank centerline need to be parallel, but not necessarily "inline" with each other. As mentioned, a u joint likes to be a little off of perfect, but the margin of error, if excessive, will result in premature u joint wear, and use up HP overcoming the friction created. Just as a "perfect", (nothing mechanical is ever perfect), or too little angle, will also cause wear... Before you disassemble it for u joint replacement, mark the assembly with a centerpunch so you can reassemble the pieces in the same "clocking" as it was originally.......
    And yeah, black paint does dissolve rust
    Ray
    LOUD BOATS SAVE LIVES
