my new diverter
Results 1 to 14 of 24
my new diverter
    The Brown Bomber oldmudwiser's Avatar
    Apr 2010
    apple valley ca
    Default my new diverter
    Just got my diverter. tested it last night, made the world of difference. but i want more of a rooster tail is there a way to cut or trim the nozzle?
    thanks Eric
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    What are you running it on? If you have a split bowl JG you can add wedges.
    Wags
    Apr 2010
    apple valley ca
    its the stock berkley bowl i think?
    Sep 2008
    Yuma, Az
    post some pics of it. if its not a split bowl, your limited on your rooster tail.
    heres a video i made a few years ago.
    boatless....
    yeah just grind the top edge a little. I went about a 1/4 inch with no problems. You just dont want to grind so much that the inner seal blows out. Measure 1/4 inch from the top and then taper it to 0 on the sides.
    I personally think the guys a place kinda messed up when they casted the diverter. They have way more down adjustment then needed.
    Apr 2010
    apple valley ca
    so should i cut or wedge? im at work and all i have is my phone camera.
    but the bowl comes out of the transome and then the nozle bolts to the
    bowl?
    oldsmopile equipped
    Lake Lansing MI.
    Quote Originally Posted by oldmudwiser View Post
    bowl?
    yes, if you have a flange at the back of the bowl its a "G" style bowl which means you can bolt a wedge on it, you could also buy a "rooster booster" let me see if I can dig a pic up for ya. there are also pics on this site of where to cut or grind the diverter.
    bowl?
    Wedge.
    oldsmopile equipped
    Lake Lansing MI.
    you can buy this from www.arsmarine.com, its a rooster booster.
    oldsmopile equipped
    Lake Lansing MI.
    a wedge will get the same results I think, its just a different way of going about it, I would also bet that www.jetboatperformance.com would also sell them, I just have never seen them on there site.
    Let me know if you need some pics. I can prolly take a few later for you.
    You can wedge or grind or both. I ground mine and you would be hard pressed to tell where I did it. Its one of the best free and easy mods I have done. There is no structural problems by doing it either. Personally I would grind and then add some wedge later if its not high enough for you. I pretty much doubled my roost just by grinding and I could probably do a little further.
    Apr 2010
    apple valley ca
    ok im ready to grind... so just grind the top part to make it go up further right like 1/4 in?
    oldsmopile equipped
    Lake Lansing MI.
    found a pic.....
