So far not so good.....
Results 1 to 14 of 19
    Aug 2010
    Shawnee, OK
    Default So far not so good.....
    I just got my 74 Tahiti Super Tiger. Been to the lake eight times, none of which have been a good trip! First time the boat would not turn or go into reverse. I found the steering cable routed wrong and a clamp off the diverter (?) cable. I shut the boat off and then it would not start. Had to be towed in. The next time the boat turned great and would go into forward and reverse. Ran one tank out of fuel and then again the boat would not start! Was also missing above 4000 rpm. Put a new distributor, coil, plugs and wires in. Took the boat to the lake to time it and it wouldn't crank over. The starter solenoid was bad. Replaced the starter and took it back out. The new coil was bad. To shorten a long story it never came off the trailer five times and has been towed in the other three. The last time the alternator went bad. Now she has a new starter w/ solenoid, coil (x2), plugs, wires, distributor and alternator. I have a new intake for it but not yet installed.
    The guy that towed me in last time was in a BEAUTIFUL pickle fork and he said "that is the fun in owning one of these boats. Wrenching on it." I agree to a point but it would be nice to actually wrench less and be able to have it on the water a little more. Anyone else have this many problems?
    Glendale Arizona
    Quote Originally Posted by Jetgod View Post
    Welcome to the wonderful world of boating. You're preaching to the choir. Most of us started out the same way.
    Keep after it and soon you'll run out of things to fix.
    P.S. depending on how your tanks are plumbed, running one out of gas and you're effectively out of gas unless you have the means to shut off the empty tank via a valve of some sort.
    Feb 2010
    Way Far Nor Cal
    Yep on my first boat.. first time out ran pretty good.. first day second day starter was kickin out, so had to go get a starter..
    Second time out ran good, when i got home to rinse the lake water outa the engine, i had no Oil Pressure.. pulled the motor, found the oil pump pickup in the pan..
    Had to put a Small block in it.
    runs pretty good for the time being.. but at least its a Jet drive.. makes it easy for me, cuz its an engine and a Jet.
    Redding, CA
    No, I have had no problems in the 4 years I have had my Miller.
    There was some small stuff, though.
    Our first trip out just to see how it ran, we got passed up by a bass bout with a 150 outboard. Miller did MAYBE 45-50.
    Pulled the Engine, built a new one with Brodix heads and a tunnel ram. Ruined the Hyd. cam on the trailer during break in, replaced it and flushed oil and filter several times. Tried to get a summer out of it, blew it up second trip. Built new engine w/ new 4 bolt block, complete forged rotating ass., Hyd. ROLLER, same heads and T-ram. Decided to do a rail kit since motor was out, ended up resetting intake and tricking out the pump. Installed new carpet since everything was dismantled. Re-assembled boat, put it in the lake and saw severe cavitation at 50 MPH. Drove it anyway, destroyed fresh impeller, almost sank boat when intake came loose and spun the boat out. Nearly tossed Wife and myself.
    Pulled boat apart, had a TRUE professional reset intake, SS impeller. reassembled boat.
    Now runs GREAT, does 86 MPH, starts first time every time.
    Took 3 seasons, countless hours, I don't know how much money. Still no rail kit.
    Been towed 4 times. (Once by a....Jet ski)
    BUT, worth every dime and every minute spent on it.
    Just keep eliminating the small glitches, soon, it will be more dependable and fun!!
    Many of these boats get passed around by people who just try to get it on the water now and then, or don't understand what is required to make them dependable.
    You may have several owners worth of "rigging" stuff to work.
    It doesn't require TONS of money, or high dollar everything.
    BUT, it is the small details that will keep you running. There can be NO loose wires, You should be able to isolate your fuel tanks, battery must be good. go through it front to back with a screw driver and some wrenches.
    You have a fuel system, a very basic electrical system, a very simple drive system. Address each one for small repairs and check all nuts and bolts each trip. Shit comes loose and that is the main cause of system failures, IMO.
    I always find small stuff that could get me towed if I didn't check it out every time.
    I spend about an hour before and after each trip checking the boat out. (Sometimes a couple days after the trip!)
    Welcome aboard!!!!
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Default Testing?
    There is a distinct difference between going to the lake/river to "test" the boat, vs loading up the family, all the toys, a picnic lunch and the icechest.... With an "outing" planned, not only are you and the family disappointed, but you, as the "wrench" are under a lot of pressure to make sure everyone has a good time....
    Back up to the "testing" trip. Just you and a buddy, no toys, no picnic, no PRESSURE......Once those testing trips produce a dependable, FUN boat, then, and only then, plan your family "outings" and have FUN....
    Fact, 5 boaters meet up at the lake for the weekend with all the frills, 3 will fail, of those 3, 2 will be terminal , then at least 1 of the other 2 will fail.....At the end of the weekend you're lucky to have 2 running trouble free......Aint this boating crap FUN!!!
    Really, devote some "testing" time before the family commitments, it's a lot easier on the stress levels..........
    Ray
    LOUD BOATS SAVE LIVES
    oldsmopile equipped
    Lake Lansing MI.
    I Ruined the Hyd. cam on the trailer during break in
    did you ever figure out why it wiped the cam? did you use zddp or any other kind of breakin lube? just wondering because I just broke my cam in and so far so good, after hearing all of these stories lately I think it will be the last flat tappet cam I ever buy, time to start buying rollers
    Aug 2010
    Shawnee, OK
    Yes I ran the left tank out then switched to the right tank via the valves in back. The gauge doesn't work in the left tank but seems to work okay in the right.
    Lake Havasu az.
    [QUOTE=thatguy;1209172
    ![/QUOTE]
    I bet you haven't had the 'pleasure' of gettin towed in by a red olds yet have ya
    Sheriff Joe Arpaio
    Senior Member harley222's Avatar
    Sep 2009
    i just got my boat this year and i have had a few problems my self. Trust me be patient and you will get it, its worth it trust me
    "Mad" Member Jet Mad's Avatar
    Cape Town, South Africa
    Been at it for 4 years with my Kona with 455 Olds. Everyday I look at the boat I see something I still want to change.
    It never ends.
    I am also in the process of restoring a original Hamilton Javelin with 455 Olds and 3 stage Hamilton Jet, a 2 stage Hamilton with 302 Ford, single stage with 298 Holden and a 21ft Supra Wake boat.
    I wake up some nights in a cold sweat and suffer from Jet Boat nightmares.
    Just keep at it, you will get to know your boat like the back of your hand and sooner or later you will forget about the teething problems you had with it and enjoy it with your family.
    Wikus
    Glendale Arizona
    Quote Originally Posted by Jet Mad View Post
    Wikus
    Back home we'd call that a glutton for punishment.
    Funny thing is when I got them they were all running fine, but nooo I can make them faster, shinier ..........
    Wikus
    Default Old sayiing....
    Wikus
    Well you know the old saying, "if it isn't broken....keep messing with it until it is"
    Ray
    Redding, CA
    Quote Originally Posted by Sold honda.bought hondo View Post
    I will NEVER get towed by a pink anything!!!
    Tommy
