Quick fuel line size question
Results 1 to 14 of 31
    Default Quick fuel line size question
    Is a -8 ok for 700 hp? In my case its about 500 motor and 175 nos. Gonna try to run that all off my clay smith fuel pump. I was thinking coming off the pump with a -10...into a y block...and -8 from there. Any opinions?? Suggestions?
    i would run a seperate pump for the juice.
    also invest in a safety fuel psi switch that wont alow you to spray unless you fuel psi is correct.
    Mar 2010
    Clarksville, TN
    I'm runnin 8 to my 2 750s without any problems but I also have a fuel log ... I would think you would be just fine
    415 M3
    So Ca
    What type of fuel tank?
    Quote Originally Posted by gunslinger View Post
    I have 2 tanks....both are-10 outlets(now).....I run one tank at a time. That way I usually make it back to the ramp.
    Is this nos bottle too close to the engine here??...sorry I didn't want 2 start 2 threads.lol
    in a daytona my buddie mounted his tank to the left of the drivers seat in the sponson, mounted to the stringer, out of the way of everything, plus you can reach in while driving to turn it on and off when needed
    You are probably right...as far as where to put it. I would still like to know if its too close there. On the on and off thing...keep in mind it's a 175 shot minimum. I am gonna have to grab the timing light and back the timing of to run the nos.
    buy the msd digital 6 ignition box it will take care of all you timing issues.
    PM me and i will let you know what im doing and what ive been told by people WAY smarter then me
    digital 6 is bad ass for nitrous
    One thing at a time...I can't afford a new ignition right now...or probably any time real soon. I thought about putting it left of the drivers seat....that wouldn't be anywhere near a stringer though.
    IF you can't afford the right stuff for nos to set it up, you will not be able to afford the damage. from not having the right stuff. if your going to run nos spend the money to do it right and even then it still cost $$$$$$$
    415 M3
    So Ca
    Do the tanks have siphon tubes? You have to look at the system as a whole. If you are dealing with a pair of pinner siphon tubes that are intended to supply a stock engine, it dont matter what size fuel line/pump you have.
    The tanks originally had tubes about the size of a pencil. I fixed that a couple of years ago. I may edit in a pic. The tubes are 1/2" alum tube...wit a -10 top. As far as not being able to afford to blow chit up...thats a given.lol If I'm going to blow chit up I'd rather do it in the fall. I have had my kit since may. It would be a good excuse to put some higher compression pistons in there.lol
    http://www.performanceboats.com//showthread.php?t=72571
    you need this,
    I had my bottle on the left bottom of the drivers seat, mounted to the seat
    remember the bottle needs to sit at an angle so the pickup tube is in liquid.
    #55
    Quote Originally Posted by bob fry View Post
    Yep.
