would u run this impeller/bowl?
Results 1 to 3 of 3
    Sep 2008
    Rancho Cucamonger, CA
    Default would u run this impeller/bowl?
    i dont see any cracks on either, but i do see some dings and scrapes on the blades of the impeller (probably hard to see in these pics).
    the bowl has the same sort of damage, nothing bent just dings & scratches.
    is this okay to run as is in a family thrasher boat? it's not ever gonna see 60+ on a gps...
    the pump turns freely and doesn't have any play in the bearings.
    just wanna know if it's worth my time to repair/replace this setup? thanks!
    Looks to have seen some better days, here is a great guide to the working of a jet pump. The impeller needs a little attention, give this a look, you will figure out what you need to do.
    http://www.americanturbine.com/downl..._oh_manual.pdf
    Ladera Ranch
    It might cavitate a little, but it will run. Might be a good idea to measure the wear ring clearance if you can get to it, too.
