how much hp to turn these
Results 1 to 6 of 6
    Senior Member tx-19's Avatar
    wittmann,az
    Default how much hp to turn these
    Done.... So.Bay*310*'s Avatar
    So.Cal
    Quote Originally Posted by tx-19 View Post
    Joey, It takes a FORD to turn that!
    See ya at BR bud.
    sacramento
    the question is how many hp to turn that baby 6500rpm1000hp might get you 1200rpm?wild guess
    Senior Member Jetboat Jared's Avatar
    Apr 2009
    independence oregon
    wtf is that thing lol crazy impeller
    wittmann,az
    i had to do some work at a place called national pump.they had impellors that were normal size all the way up 2 to 3 feet round.they have a dunk tank with all kinds of things hooked up to read pressure at all rpms.it will tell you how much water is being flowed at all times.
    Depends on how many you stack together. Seen as many as 8-10. Generally, don't take as much HP as you'd expect because they turn fairly slow. 900-1200 RPM.
    As a kid, I worked in a general machine shop that, among a lot of other general machining, used to rebuild pumps like this. As a first year apprentice got to clean and disassemble them. Heavy, dirty, sucky work. As you progress, you'd get to metal spray the runner necks, sleeve the wear rings, and replace all the bushings... Work like that kept me in school!!!
