What bowl do you fast guys run?
Results 1 to 14 of 35
    Southwest corner AR
    Default What bowl do you fast guys run?
    What bowl do you fast guys run? I have been looking at bowls and ask witch is best in stock form? No mods just bolt on and RUN! Berkely, American Turbine,Aggressor,Dominator. This is on a Berkley pump. WT
    WT
    WFL Crew!!!
    Glendale Arizona
    Coby.................You got the sickness?
    Senior Member hotbo's Avatar
    lake Ouachita AR
    American Turbine/dominator.,are the same these days when bought new.
    we put a new one on dads first of this season and right out of the box i was impressed with the inlet and exit vanes.
    oh sorry you asked for the fast guys
    it did break the steering wheel from the take off thrust.
    WFLC
    2011 Performer SS
    built by Scott Seastrom.
    The Right Coast/SE-PA
    Anything with a prop...sorry
    Senior Member bp298's Avatar
    LHC
    a lot of guys have gone to the amt, but a lot also still run berks. none of 'em are out of the box stock...
    just a little information ,although Late American Turbine and Dominator bowls look nearly identical the wall/casting is thicker on the Dominator as is the OD , the AT bowls are rated to approx 500 hp, if you use the Dominator bowl as a berk replacement it requires milling/enlarging the transom adaptor (if used) obvopusly doesn't matter with set backs , BTW The Dominator Extruded hone bowl is sweet but a little spendy , just send one to Canada but got a pic first
    Ladera Ranch
    Exclamation
    im running an aggressor 9 vein that is detailed. I removed an amt 11 vein(iirc), and while I didn't get before & after GPS figures, I think the amt was better for my setup based on seat of the pants feel.
    Question
    Not to much talk about Legend anymore > did they fall off?
    Denton, TX
    The real fast guys run a WJ
    Aggressior 9 vein worked over by tommy
    Southwest corner AR
    Thanks for your info. Next step more motor!
    Yes Dan Baaaaaddddd! WT
    WT
    WFL Crew!!!
    throw some nitrous on that bitch coby dont be skeeeeered nice 300hp shot on your motor and it'll be plenty quik and fast
    lake Ouachita AR
    so far i have seen him shoot 100 shot
    he needs to lay the jets to that Zex deal and maker smoke
    or just let me ride with him next gathering fort some reason they go faster with me as a passenger
    it might be my wing effect,or my man tits bouncing
    WFLC
    2011 Performer SS
    WFL Crew TINTDESIGNZ's Avatar
    East Texas
    uhhhh...you my friend are a NUT!!! ahahaha!
    WFL CREW!
    http://www.performanceboats.com/cont...-magazine.html
    Everybody wants some...I want some too!
