Xtra Solenoids On Diverter Pump?
Results 1 to 6 of 6
    Senior Member CP598's Avatar
    Sep 2008
    Default Xtra Solenoids On Diverter Pump?
    Does anyone know why the hydraulic diverter pumps have the extra set of external solenoids compared to the standard "Bennett" pumps? You know my next question, will a standard Bennett pump work?
    Thanks.
    Vern
    Anaheim/BHC- the Shack
    For the returns.
    Quote Originally Posted by slowride View Post
    For the returns.
    X's 2 They work like heart valves to control flow, back flow and postion Tom
    New Jersey
    Quote Originally Posted by CP598 View Post
    Bennett trim tabs use a single acting cylinder (pressure to extend and a spring makes them retract). This is acceptable because the water pressure is always trying to force them up to thier collapsed position.
    Place uses a double acting cylinder (pressure to both extend and to retract) to accurately control the diverter trim setting. In this case you need the positive control both extending and retracting because there is no constant force to help control the position of the diverter.
    ...will a standard Bennett pump work?
    No
    Doug
    Sep 2008
    Quote Originally Posted by Real McCoy View Post
    No
    Doug
    Thanks to all that replied. Now, can I buy the extra solenoids to put on my standard Bennett pump?
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    Thumbs up
    NO.
    The two pumps do not work the same. You can make a simple circuit to make this happen. I'm a hydraulic specialist, I can make you one. If interested send me $1,800.00 and I'll get right on it.
    Mark
    Pump is energized, turns one way only. Two valves open, one valve goes to the cylinder port A, (rod end) the other valve comes from the cylinder port B, (cap end) nozzle down.
    The valves open, one goes to cylinder port B, the other comes from cylinder port A, nozzle up.
    You could use your Bennett pump to supply a manifold with the four solenoid valves. Then use diodes and trim switches to energize the coils.
ID:	84499   Click image for larger version.
ID:	84500   Click image for larger version.
ID:	84501   Click image for larger version.
    Loose, the Dogs of War!
