I'm Screwed!
Results 1 to 14 of 38
I'm Screwed!
    Lexington, KY
    Angry I'm Screwed!
    Well, tonight I got started on my plumbing. I couldn't find the bolts that held the thermostat housing down, so I grabbed two bolts off my work bench that fit through the thermostat holes. Unfortunately, these two bolts were not the right size, but they certainly wanted to think that they were the right size they felt like they were threading, until they were almost at the tightening stage. At that point they just kept turning and to my dismay when I took it all back apart the threads came out with the bolt! DAMN! DAMN! DAMN!
    Looks like I either have to get some helicoils or a new intake. Which I have been wanting for awhile but down have the money. I would love to have a Weiand Team-G or something like that, but in the tall deck version, so I don't have to use my spacers that I spend so much time making. Maybe some day.
    The Earth
    Blog Entries
    24
    Easy fix with some helicoils or timeserts.
    Senior Member tx19condor's Avatar
    is there enough meat on everything to drill it out and tap it the next size up?
    Lexington, KY
    Quote Originally Posted by tx19condor View Post
    Unfortunately no. I would have to drill everything out, intake and thermostat cover, and the walls would be pretty thin on the intake bolt holes.
    That's what I figured. Just have to go by my old work, and get my old boss to give me a couple of the right sized ones. Just one more step backwards in this whole process. Thanks.
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    Just Helicoil it. Go to AutoZone and pick up the kit for about $20.00 and an extra set of coils. You get everything to do the job right. Drill, Tap, Insert, and put the bolts in.
    Senior Member cave's Avatar
    Mesa, AZ
    Why cant you tap in the the next size up Metric? Looks like you have plenty of material.
    Takin it home
    not ****** little squirt's Avatar
    Waikiki, HI
    yea, i wouldnt worry to much, thats an easy fix, and it looks like you have plenty of material to either drill one size up and tap, or set in a pair of heli-coils. just a little step backwards, no biggie
    not banned
    Senior Member PlacecraftTunnel's Avatar
    Wittmann,Az
    You have enough material to put in helicoils. Easy fix
    TJS
    TJS is offline
    CT
    Ya that is an easy fix as others have stated. I had to do this on the lake floating around at a dock. Cordless drill and heli-coils were actually in my buddies tool box on the boat.
    T.J.
    Lexington, KY
    Talking
    Cause metric sucks! I hate when they put metric bolts on American cars. It pisses me off because I mostly have English size tools.
    Cantard 71hallett's Avatar
    snow bank
    Dont forget the extra beer your going to need to keep the drill bit cool!!
    snow bank
    7/16ths will work and you can even reuse your washers.
    El Cajon, CA.
    When it's on a american engine it's called standric. Ford did it for years, half standard and the other half metric.
    Glendale Arizona
    It almost looks as though it's been heli-coiled already. I Don't usually see aluminum threads come out all in one piece like that. Is that section of threads aluminum or steel?
