555cid aluminum turbocharged engine - Page 132
Page 132 of 132 FirstFirst ... 32 82 122 129 130 131 132
Results 1,835 to 1,840 of 1840
  1. #1835
    okie, lake Texoma
    Quote Originally Posted by schick View Post
    Thanks,
    I assume if you can run a lenco drive shaft, your engine is set at pump intake angle (aligned with pump shaft 5*)? I was wondering what angle would be too steep of engine angle? The concern is having the engine oil in the pan. I run a R intake (7*), the increased angle is a concern for driveline geometry. Am considering having a oil pan made with floor in the pan parallel with the bottom of the boat, or going to a dry sump? Maybe I'm over thinking it?
    Be safe, schick
    I have a steel pan made that way--- good idea
    H8-2-W8
    [email protected] first pass
    okie, lake Texoma
    Making another big change. I am going center steer--- it can be changed from center steer single seat to dual seat - side steer in less than an hr
Name:	center streer.jpg
    H8-2-W8
  4. #1837
    Olympia, Washington
    Looks great Haas!
    Somebody's getting ready for koth season😜👍 turbos ftw💪😈🤘
  7. #1839
    okie, lake Texoma
    Probably be best landing this thing from 150+mph setting dead center.
    H8-2-W8
  8. #1840
    okie, lake Texoma
    Took the boat out a few times and broke the rings in. All the vitals look great. Changed the oil and cut the filter and it looked great--- very clean. I think we are ready for some ACTION! King of the Hill races in El Reno coming up in about a month! July 19th-21st
    H8-2-W8
