555cid aluminum turbocharged engine
Page 1 of 132 1 2 3 4 11 51 101 ... LastLast
Results 1 to 14 of 1844
    okie, lake Texoma
    Default 555cid aluminum turbocharged engine- H82W8 boat thread
    I finally have the 555 turbo engine mocked up in the stealth and am ready to start fabbing some of the pieces necessary to connect the turbos to the intercooler , and the exhaust from the turbos. Just thought some of you may be interested in seeing a few pics.
    Now I need to pull it back out and take the oil pan to have the drains welded in. Just had to do a mockup to make sure that they wouldnt hit anything first
    H8-2-W8
    [email protected] first pass
    I can understand your enthusiasm. But please try to keep the bling porno to a minimum, or I will be forced to report you to Admin. Looks good
    Senior Member badbug3's Avatar
    Default Hey Hass, what head do u have on that thing?
    what are u running for fuel?
    okie, lake Texoma
    Quote Originally Posted by badbug3 View Post
    I have stainless saddles in the boat and will have one with 91 pump gas to cruise around on and one with C16 in case I descide to turn the boost up.
    H8-2-W8
    that Alumi block whats it weigh?
    How much power are you figuring?
    Oh yeah...looks like fun....good luck with it.
    S CP
    okie, lake Texoma
    S CP
    Didnt weigh the block but I put the mount on it and carried it across the shop and put it on the engine stand by myself
    1800-2000hp when set on kill.
    H8-2-W8
    Wet
    Wet is offline
    East Hampton, CT
    In a turbo app, do the header tubes need to be the same length for each cylinder? Doesn't look like it in your photos, guess it's not required?
    what chargrs? they are s400's but what size?
    okie, lake Texoma
    Quote Originally Posted by glastornjet73 View Post
    75mm, 1.32 housings.
    H8-2-W8
    Ada, Michigan
    Looks excellent.
    Plenty of room for piping with the motor that far forward.
    The intercooler tucks in nice there too.
    I've got a selection of left over aluminum bends I'll donate if you need some.
    3" , 3 1/2 " , 5"
    okie, lake Texoma
    Looks excellent.
    3" , 3 1/2 " , 5"
    Thanks Mark, I'll contact you first before I order anything.
    H8-2-W8
    JGB
    JGB is offline
    Senior Member JGB's Avatar
    YUMA
    S CP
    Dart and Brodix aluminum blocks weigh between 140 to 150 lbs
    okie, lake Texoma
    Quote Originally Posted by Wet View Post
    Not detrimental on a turbo deal. A proper turbo cam doesnt have as many degrees of overlap and doesnt rely as heavily on the scavenging effects of the exhaust system. Atleast thats my understanding .
    I will be installing a 5 degree wedge under that carb to lean it to the front of the boat , for two reasons, to help level up the float bowls while in use and to give my dizzy a little bit more room for that charge pipe to pass over it.
    H8-2-W8
    wow how much boost you think u will produce my friend has on 475 .80 t4 with the smaller turbine wheel on his cummins 75+ lbs when hooked to a sled and 950hp on fuel and air only kinda curious as to how diffrently these would work on a gas engine
    have you thought about getting he race covers? they deffinatly make a diffrence! if so give engeneered diesel they can set you ut with em
