21 Daytona v-nose tunnel questions.
Results 1 to 9 of 9
    Senior Member junkyard's Avatar
    PHX AZ
    Default 21 Daytona v-nose tunnel questions.
    Im looking at a 21ft daytona v-nose tunnel. Fist question how difficult and or costly is it to have the transome wood redone? Second question is this boat was setup as a outboard, has anyone converted one of these to a jet and how difficult of a project is it. Any help would be appreciated.
    Jul 2009
    wow good question cause i passed on an eliminator because it was originally an out board and was told it couldn't be done because the stringers were to thin i want to know if i should kick myself in the a$$ for passing it up and it was stupid cheap too cause the power head was missing all kinds of parts...
    Senior Member Futs's Avatar
    Orange CA, Big River
    Sure it can be done. People do it all the time.
    My question is, what is a V noze? Sure its not a TPR edge 21'?
    Quote Originally Posted by junkyard View Post
    My boat is such a whore...it came out of the factory as an IO...the guy I bought it from was trying to convert it to a wacker....now its a squirt boat.
    Senior Member bead's Avatar
    Default mine was I/O
    now a jet, cant even tell. An outboard is even better just a few holes to repair and then you can have your pump set as far back as you want.
ID:	87825   Click image for larger version.
ID:	87826   Click image for larger version.
ID:	87827   Click image for larger version.
ID:	87828   Click image for larger version.
    Funny stuff I still got the "Chunks"
    " Live Laterally " Dominator's Avatar
    Phoenix
    You must be high! Finish your god damn Dayrona first. Quick dickin around with all these other projects. At this rate your Eliminator will NEVER get done. Oh well guess me and pop's will have all fun!
    " NO MOTOR NO BOATER "
    " I'd rather be riding in my boat thinking about God, than in church thinking about my boat ".
    Wet
    Wet is offline
    East Hampton, CT
    My Daytona was originally built for an outboard, but became a jet before the rigging.
    PHX AZ
    This boat has steps in the bottom of all three sponsons. Ill try to get some pics up to day. I would imagine at least the steps in the center sponson would need to be taken out. Also looking at the boat again the whole transome does not need to be re done. It has a crack in between the two mounts for the Ob.
