Scoop tray mounting hardware?
Results 1 to 3 of 3
    Las Vegas, Nv
    Default Scoop tray mounting hardware?
    What hardware are You guys using to mount the scoop trays to the carb/intake? I have a harwood fiberglass scoop, with an aluminum scoop tray. I have a set of Goza under carb plates with studs, but I cannot seem to make them work with My linkage and most of all, my nice ss hard line fuel line on the carbs. My carbs are a set of 4150 style side x side carbs.
    The set up is whats in the pic below. If You have any close pics I would like to see how You have Your scoop trays set up....Hal
ID:	87879   Click image for larger version.
    B1 Racing cs19's Avatar
    Hal, sorta hard to follow your question but we generally pick up the 2 rear studs for the back carb and tie the tray into those and the same off the front 2 studs off the front carb. thats how we mount the tray to the carbs.
    Las Vegas, Nv
    Thanks Chris, That is exactly what I wanted to know. I was looking for pics for mounting the tray without having to buy a different under carb mounting plates.
    I have a set of Goza under carb mounting plates pictured below.
    The plates look like they may interfear with My dual carb linkage, But most of all they deffinatly do not work with My Stainless hard fuel lines.
    The part of the plate that has the square holes is too wide to clear the inside space of My fuel lines and I do not want to have to modify the lines or the plate to make it work. If I had SS braided lines it probobly would not be a problem if it works with the linkage.
    If I can extend the carb studs and mount that way and it be safe enough not to fly off then that would be an easy and inexpensive way to mount the tray. If I had to buy two new mounting plates from summit or jegs it would cost Me atleast 150 bucks and I am trying to avoid that expense.
