Ride plate/setback ????'s
Results 1 to 14 of 17
    The Good mrjoshua's Avatar
    Aug 2010
    Albuquerque NM
    Default Ride plate/setback ????'s
    Any benefit to a ride plate w/o setting back the pump? I have a 18' Tahiti W/ a SplitBolwl and diverter. I have not tried the various straight or droop combinations first. It will have a new BBC W/ an"A" impeller. It previously had only a "C" bowl with limited runs W/ diverter so I do not have a "baseline" for comparison. How is the setback determined? Any opinions?
    Angier, NC
    rideplate and shoe is always good wouldnt worry about setback on that hull
    HOT ROD BOATS
    ANGIER, NC
    pump & parts
    fiberglass work
    s.s. hard lines custom made
    pretty much anything
    Santa Clarita
    Quote Originally Posted by mrjoshua View Post
    If you are pulling the intake to be machined for a shoe/rideplate, that would be the time to do the setback if you decide to set it back.
    Shell Knob, MO
    x 2
    Aug 2010
    Albuquerque NM
    How is set back determined?
    Ladera Ranch
    Trial and error. X3 per the above. Save your money for another hull if you want to go faster.
    Jul 2010
    Set back provides opportunity to minimize hull wetted surface and consequential drag. It moves the lever arm about the CG establishing hull attitude while making best use of available thrust. A ride plate is a must with the set back but very effective without set back. To set the pump back you need to understand the boat's CG and ride angle. With this information and a factor for wetted surface drag you can set the pump to the best thrust angle. Without the information above you will be doing a huge amount of work that may not net the results you desire. Remember also that when the pump is further back the intake is also further back further allowing less wetted surface.
    any benefit to a ride plate w/o setting back the pump? I have a 18' tahiti w/ a splitbolwl and diverter. I have not tried the various straight or droop combinations first. It will have a new bbc w/ an"a" impeller. It previously had only a "c" bowl with limited runs w/ diverter so i do not have a "baseline" for comparison. How is the setback determined? Any opinions?
    what year tahiti??
    Aug 2010
    Albuquerque NM
    76' super tiger
    B1 Racing cs19's Avatar
    For sure do the shoe and rideplate, setback depending on how long you are keeping the boat and what your goals are.
    Aug 2010
    Albuquerque NM
    It's going to be a ski/cruiser first. Building a BBC 461 or 468 (depending on how much i have to bore it.) Comp roller cam 256/302 .566 and roller rockers. single plane intake and 850 dp mech secondaries. 9.5:1 compression. W/ "A" impeller. I'm not sure how much HP or Rev I'll see at our altitudes but should be faster than my old 455 and 50-55 mph. i used to get. Will the ride plate help with planing out faster and also "air the boat out" a little more? I know this is not a "speed" hull. This will be a lake boat sometimes on 1-1.5 ft waves. will stability be affected?
    Mj, heres an example setback Berkeley on a similar Tahiti completed last season , worked out well call Josh or myself if we can help Tom
    The Right Coast/SE-PA
    Question
    Tom, not to jump topic here but do you have any better pics of those two Suction Housing pressure-tap locations?
    Thanks, Ray
    Wait a second there...I think I recognize that transom.lol Hammer..I believe you want the taps about 1 inch in front of the wear ring...pretty much as high..and low as you can get them. Ever since this was posted ....I wondered how a tahiti would act with a set back....I wondered if it would make them shut down better...worse...or about the same. My old one spooked me a couple of times...and that was only doing 70 ish.
