Gen V heads on Gen 1V Block
Results 1 to 7 of 7
    Salem,Or
    Default Gen V heads on Gen 1V Block
    Any one running Gen 5 heads on Gen 4 Block ???????
    WOULD YOU ???
    Quote Originally Posted by BrotherWolf View Post
    WOULD YOU ???
    The Gen 5's will work on MK4's , check out the Comp rocker "conversion studs" to make the valve train adjustable Tom
    Salem,Or
    more worried about the water passages/jackets etc
    Josh and I have succesfully done these several times without incident Tom
    California
    The water problems are with mk 4 heads on a gen 5 blocks not the other way around. Many mk 4 heads don't have enough material to succesfully seal the water passages near the lifter valley side on a gen 5 block, gm fixed that prob on the gen 6.
    Salem,Or
    thanks Just checking
    Senior Member crf311's Avatar
    Meraux, LA
    What head gasket would you use when you put gen5 heads on a gen4 block?
