572 and Turbo
Page 1 of 9 1 2 3 4 ... LastLast
Results 1 to 14 of 126
572 and Turbo
    Member LIBERATOR681's Avatar
    Sep 2010
    PA.
    Question HELP---Turboed GM 572
    All NEW
    Does any one have a clue on putting a TURBO on a 572 I'm looking for any answers I dont even know if it can be done or if it would even work ??????
Name:	Greg's 21ft. jet 226.jpg
    New here Beer:30's Avatar
    Bakersfield, CA
    Quote Originally Posted by LIBERATOR681 View Post
    All NEW
    It wouldn't be A turbo, it would be SOME turbos. A single turbo to feed a 572 would be off of a John-Deere or similar and would take a month of Sundays to spool up.
    Sep 2010
    PA.
    Thanks for taking the time to get me started. I hope to find out more as I go ...
    Senior Member Futs's Avatar
    Orange CA, Big River
    Really? You didnt see the thread down a few about a turbo charged 555?
    Well, if your really serious, you should probably read this. It will make your head spin......
    Heres a link incase your to lazy to look for it or use the search mode..........
    http://www.performanceboats.com//showthread.php?t=74740
    Sep 2010
    PA.
    Default Open eyes
    I guess I need to take the time to look around more. I get very little time to sit for any amount time with all that is going on in life .
    Thanx again GREG
    okie, lake Texoma
    This can be done with a big single. Its been done many times and there is a large debate over which way is best.
    Twins on a jet boat just turns out better as you dont need to have all the plumbing to connect the two sides of the engines exhaust together.
    But 572 inches breathing through the proper sized BIG turbo wouldnt be any more lazy to spool than twins.
    Also two turbochargers like I have are way less expensive than one single large enough to feed a 572" monster.
    H8-2-W8
    [email protected] first pass
    Senior Member cave's Avatar
    Mesa, AZ
    LIBERATOR681, Hass828 and Unchained have done some tuboizing of their boats. Maybey search for some of their threads. Good info from them on Turbo charging. You can also check out the Forced Induction forum here.
    Takin it home
    Senior Member UNASHAMED's Avatar
    Sep 2008
    Tucson, Az
    Post in "forced induction" 4 spots down from this on the main page. May have better luck.
    "Don't make me get my penguin"
    Sep 2010
    PA.
    Default General
    I would like to say thanks alot . I'm busy now I will write more when I get some time. This is alot of help. Keep on going I will take a break when I'm dead... Maybe
    PA. Greg
    JGB
    JGB is offline
    Senior Member JGB's Avatar
    YUMA
    Wow, is this the Dyno section now? I dont have any info for you, but good luck I hope you bulid 2,000+ HP.
    WOW its going to be a LLLLOOOONNNNGGGG winter
    #55
    Quote Originally Posted by UNASHAMED View Post
    For sure, that's the place to post this. He'll get lots of feed back. Should be an interesting thread.
    Depending on his power needs I'd think a Pro-charger or something to stay away from the heat, but a properly size single would be cool, as Haas stated abit pricey though.
    S CP
    The Right Coast/SE-PA
    Thumbs up
    I like Turbo's...just something about how the power comes-on
    Can't imagine I could add them to my existing 468 but I sure like Turbos
    I thought you liked Wackers
    #55
