12ja-b
Results 1 to 10 of 10
12ja-b
    AAARRRRRGGGGGGG!!!!! Motomatt68's Avatar
    Nov 2009
    Default 12ja-b
    I have been reading and searching the forum for information on a 12JA-B that I got this weekend. I cant even find something that describes the difference between a split bowl and a non-split bowl. Can anyone point me to some threads or a page with good info?
    I am trying to decide what to put in my boat the Berkeley or keep my Jacuzzi with the energizer kit.
    Matt.
    Quote Originally Posted by Motomatt68 View Post
    Matt.
    A's B's and G's were "two piece"/split bowls, C's (& E's) were "one piece bowls , your 12JA-B was an early Berk split bowl offering with a B impeller originally ,some subtle differences from a later 12JG but a good piece nonetheless
    "C" bowl
    split bowl
    Member neverenuf's Avatar
    North Texas
    This is an early JA Berkeley split bowl that I purchased from Tom last year.
    The only differences I notice is the position of the oil ports (top) and the exit vanes are shorter than the later JG split bowl.
    Nov 2009
    What makes it a split bowl? Can I just bolt on a JG bowl? Could I bolt on a JC bowl?
    Matt.
    Aug 2010
    Matt.
    look at the housing where the impeller spins. the non-split is one solid huge thing. whereas the split bowl is actually 2 pieces.
    Here Bro I made a bowl display for ya White is "C" (one piece) Black is a split bowl (two piece) Tom
    Nov 2009
    Thanks Tom. I guess some times I just have to be hit in the head to get things.
    Matt.
    Nov 2009
    So are parts and bowls interchangeable? Could I bolt on a C bowl? or any other. I am just wondering and trying to learn about the possibilities.
    Matt.
    Southwest corner AR
    Matt.
    Most parts are interchangeable! And yes you can bolt a C bowl to the pump you have! But the split bowl (G) is more desirable for the pieces that can be changed! Short droop, full droop, snoot, ETC. to set the boats ride, launch, speed, ETC.! WT
    WT
    WFL Crew!!!
    Matt.
    Like Widetrack said the G bowl would be desireable and many parts are interchangable , A and B bowls work well too , In the case of your particular 12j "a" your somewhat limited by its early design, as the Suction (main body), pump shaft and bearing cap differ in design from the later jet siblings .On a new install this wont matter if you decide to use it Tom
