Fins
Results 1 to 6 of 6
Fins
    Retired Air Force Master Sergeant's Avatar
    Lake Havasu
    Default Fins
    Is it safe or is there any benifit in cutting the fins just a bit shorter, maybe 1/4 to 1/2 inch?
    Southwest corner AR
    Maybe a stupid question but, Why? WT
    WT
    WFL Crew!!!
    "I'm just SPRAYIN' man!!" '78 Crusader's Avatar
    Oct 2010
    McKinney, Texas
    I wouldn't touch them, leave them alone. I know what you're trying to do, you're trying to decrease your parasitic drag. However while you may reduce some drag, you'll lose controllability and for me, that is not a viable option.
    Cliff
    1978 21' Crusader, 466 CID BBF, Berkely Jet
    1966 13' Boston Whaler sport, 40 HP Yamaha Two Smoker
    987 is offline
    SWDBA 987's Avatar
    Aug 2010
    Rio Rancho, NM
    Dont touch em!!! I recently spent a considerable amount of time removing a intake from a project that had them ground clean off ....wasn't going to chance not being able to control it........I was told by a very knowledgable guru that you need them to drive against....just my 2cents
    96' 18ft Pantera Drag Boat
    Quote Originally Posted by 987 View Post
    X2
    a broken 1 will disrupt intake flow to at speed, i know that for a fact removing any from them we'll also cause cavitation at high speeds, learned that lesson too
