Carburetor Selection
Results 1 to 14 of 79
    "Floatin' Motor" BoNeS's Avatar
    Jun 2010
    Surprise, AZ
    Post Carburetor Selection
    Need your guy's input and/or opinion on selecting a new carb. What i have now is a Holley 4160 750-DP(3310-2), its ancient. Need some reccomendations on what carb i should replace this with.
    Details
    454 BBC (stock), 330hp, Edelbrock Torker 2-0 manifold, runs on gasoline
    Let me know if there's anything else that needs to be known, Thx in advance.
    Senior Member CK7684's Avatar
    Minnesota
    Why not a new one that's the same thing?
    Senior Member harley222's Avatar
    Sep 2009
    well does it run good now, im just guessin but i would stick with what works and i think a holley 750 sounds about right...Its a holley throw a rebuild kit in it and give it a try..
    "I'm just SPRAYIN' man!!" '78 Crusader's Avatar
    Oct 2010
    McKinney, Texas
    Quote Originally Posted by BoNeS View Post
    Details
    I'm running a similiar set up as you, Edlebrock Torker II intake and an ancient Holley 750 3310. I went to the Holley website, put in all of my requirements and it recomended I go with the Holley 850 CFM Model 4150 4 Barrel Marine Carburator Part #: 0-80443
    While a 750 may suite your needs, and 850 would really make a difference.
    Go to http://www.holley.com/ and see for yourself.
    A buddy of mine is running a stock 454 like yours and he put the Holley 850 marine carb 0-80443 on his motor and it woke it up nicely....
    Cliff
    1978 21' Crusader, 466 CID BBF, Berkely Jet
    1966 13' Boston Whaler sport, 40 HP Yamaha Two Smoker
    Sep 2008
    Yuma, Az
    imo, a 750dp is alittle much for a 330hp motor. I have about 400hp, with a 750dp and when I changed the carb jet's, the motor didn't like it. But every motor is different. Too much carb defeats the purpose sometimes.
    boatless....
    Oct 2010
    McKinney, Texas
    Jets and CFMs are different topics. Changing the jets increases or decreases the fuel flow while the CFM is the amount of air the carb can input into the motor.
    Cliff
    Kingman/Golden Vly, Az
    Quote Originally Posted by YumaJet View Post
    i agree ...IMO, a 650/700cfm DP mech sec carb would be a better choice!...its a "stocker"...would get much better fuel mileage & still perform quite well...remember...bigger is NOT always better! ...just sayin' my .02 cents
    FastRat
    Sep 2009
    well i dont me to thread jack but im running a 429/460 BBF with a big cam and a torker 2 intake, any ideas on what sive carb i should run?
    The Right Coast/SE-PA
    Quote Originally Posted by '78 Crusader View Post
    True > like use MORE fuel
    My 850 DP I tried (actually spent a lot of time tuning) vs my little 715vc really did NOTHING on my 468, that spins 5400 with an AA-impeller...but used more fuel
    It did pull a little harder from all the fuel dumped > but gained NOTHING at max RPM.
    > I'd bet dollars to donuts the 750 is just fine for the HP requirements of the OP's 454
    [B]Need your guy's input and/or opinion on selecting a new carb. What i have now is a Holley 4160 750-DP(3310-2),
    3310-2 are not double pumpers. They are vac sec.
    Senior Member lbhsbz's Avatar
    Long Beach
    Double pumper vacuum secondary??
    LOL. I found this when I took apart one of the carbs I bought.
    Sep 2008
    Yuma, Az
    I should've described it better. The motor doesn't make enough power for the 850DP.
    Quote Originally Posted by harley222 View Post
    Big Cam meaning? .700 plus lift? The intake isn't doing much and without knowing anything else, it's hard to say. My torker intake didn't do much for my current mild set-up, so I switched to a victor jr. intake. It opened up, and wasted a lot more fuel.
    A Holley 750 or 850 double pumper (true) with mechanical secondaries will work fine. I usually use a Holley 750DP as a starting point when I build mild motors. Depending on the application and bottom end, you match the carb the best way possible.
    boatless....
    Bullhead City, AZ
    I have seen that so much lately, What the hell ?
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Bullhead City, AZ
    An 850dp will work great !
    Jim & Amanda Rich
    CJ 72 & 53c
