Steering column Braces
Results 1 to 14 of 21
    Default Steering column Braces
    Any one with an extended Steering Column "Brace" or support to avoid Dash flex ? Pics ?
    Do you need it in the boat while running or towing? I've seen guys make stuff to support the steering column while towing so it doesn't flex as much.
    SoCal
    I have a nice brace set up for my extended column. Took all the flex out.
    Morgan Hill
    Tom,
    You talking about dash flex? The best fix is to build a brace that fits the mounting bracket of the shaft behind the dash and go forward with some triangulated brackets and bolt directly through the deck, or a cross brace on the underside of the deck..
    Speed holes are a must
    I don't have any pics, but that is how we did it in the "tin boats"....
    I will see if I can draw a diagram of what I mean later..
    GT
    Tom,
    X2 on the trianglation, I was concerned too when building mine, turned out being fine though. 4" aluminum angle, grabing the helm mounting, or 2" angle, hiding the bracket behind the helm. I was planning something like a ladder bar, cut from .200 aluminum plate, spanning to the bulkhead. I have seen them going to the floor or stringer, but would hate to get caught up in that, exiting the boat.
    Aug 2009
    Fox Valley Wisconsin
    I run a cnc plasma cutter and if you design it I can burn it. I'm sure we can work out a killer deal. I just need a clean dxf file or even a properly dimentioned bar napkin drawing to make a part. Limit 1/2 " plate.
ID:	88580   Click image for larger version.
    Senior Member PonyFiveO's Avatar
    Feb 2009
    Southbay to the Central Valley
    "Steering column Braces"
    Something like this actually exists? Are there off the shelf braces or are they always custom fabricated? Would love to see pics!
    Senior Member speedealer's Avatar
    Albuquerque,N.M.
    mounted
    mounted mine under the dash. sorry about the size of the pic. don't know how to change size
    Interesting Piece SD ,Fixed the pic for ya ! (and saved it too !)
    Tom
    (consider a photobucket acct )
    Senior Member Constant840's Avatar
    Yucaipa, Ca
    Default 2 dead pedals?
    Neither of those pedals looks to have any articulation?
    "Evolution has long been the target of illogical arguments that use presumption." - Marilyn vos Savant
    Senior Member lbhsbz's Avatar
    Long Beach
    I had a lot of flex on the old white boat, so I made a 1/4" aluminum backing plate that went on the backside of the dash to clamp the rack system in place..which improved things quite a bit, not it was still pretty floppy. I took a piece of 1/2" aluminum round stock and tapped 1/4"-20 female threads into each end that braced it against the bulkhead. One of the 3 bolts that hold the steering helm to the dash threaded into the other end. It worked well.
    Albuquerque,N.M.
    Quote Originally Posted by Constant840 View Post
    throttle is laying against stop. pedal pivots at the bottom
    Albuquerque,N.M.
    Tom
    thanks Tom, not very good at this. can you believe dash is still a virgin on a 80 earl smith tunnel
    Quote Originally Posted by speedealer View Post
    thanks tom, not very good at this. Can you believe dash is still a virgin on a 80 earl smith tunnel
    nice !
