I have to ditch the foot throttle, to much pain
Results 1 to 14 of 42
    Senior Member OverKill's Avatar
    Default I have to ditch the foot throttle, to much pain
    Guys I have been on alot of marine web sites and can't seem to find what I'm looking for. Maybe you guys can help. I'm gonna have to ditch the Foot Throttle and go with a hand throttle. What I'm looking for is a two handle control side mounted, one for the reverse bucket, and the other for the throttle.
    One was given to me by TAF but it was for a much bigger boat and wouldn't work for my 19' boat. So if anybody has any direction for me to follow please let me know. Thanks
    OverKill
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Call up Concept Marine in Montclair, Ca. John can take care of you!
    909-447-4411
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    rex has those Gaffrig ones, assuming thats what your looking for. Go to rexmar.com, click on s under the product index and check out shifters
    Thanks guys I will look into it. Got everything else done. Just need to be able to get gas to her
    OK I checked out Rex Marine and it looks like I can get what I want threw a custom order. I will have to call on Monday and see if they can help me out.
    OverKill
    Senior Member cave's Avatar
    Mesa, AZ
    Don't be a sissy Come on out today big Jim. We are all going to hang out up front. All you need to do is launch and cost over to the beach between doc 1 & 2. Should be a fun day.
    Takin it home
    Member Flash's Avatar
    My buddy has a panther jet and the throttle and gate cable are all in one. It looks just like everybody elses gate lever. Is this sort of what you are looking for?
    Quote Originally Posted by OverKill View Post
    OverKill
    you check dana marine? found the one i want there, kinda costy, but nicccceeee
    Long Beach
    Don't know why you have the pain, (injury?) that sucks but there are, or at least were, left foot foot throttles made. I've built two boats for guys, one at Rogers and a few years later one at Advantage, that had lost their right legs for whatever reason. On one of the boats we were able to order one off the shelf, we went through one of the speciality shops like 'Hot Foot' or someone like that, they make foot controls for outboards mostly but anything can be converted to use on a jet. The other we made using just the foot part of a left foot cav- plate control heli-arced to a standard right foot throttle that we cut the foot part off of. Worked great.
    The first guy was a speed skier. He wanted to get the record for a one legged skier (sounds like a bad joke) so we built him a boat to do it with and he did set the record at well over 90 in the 1/4, later it was just his regular ski boat. The other guy was a potato farmer in Idaho...in case you were wondering.
    Overkill lots of original jets especially bigger ones were rigged with dual (combo) hand controls (opens closes reverse bucket while simutaneously working the throttle) Morse MV series (old style) are around in abundance used, dont care for the new series much the after mkts are nice but spendy Tom
    Long Beach
    By the way, I have a morse dual handle, dual control, that will fit in the hole you already have in your boat that the ST control mounts in now. It looks just like a stock ST control but has a taller handle behind the standard one, it's totally different than the morse single handle setups.
    If it's something you can use, you're more than welcome to it.
    Quote Originally Posted by old rigger View Post
    Old rigger
    Do you have any pics of that control? I would love to see what you have. It sounds like something I could realy use.
    As far as the left foot throttle, that sounds like a good idea but it sounds like I would have my boat in the shop for some time while the boat guys figure out how to make it work.
    Also by ditching the foot throttle, I will endure less pain from beatings of the rough waters/chop.
    OverKill
    Brother I would love to. Give me some time and I will be out there with you all. Have fun and have a few for me will ya.
    OverKill
    Ladera Ranch
    Old rigger
    As far as the left foot throttle, that sounds like a good idea but it sounds like I would have my boat in the shop for some time while the boat guys figure out how to make it work.OverKill
    If you find an already made one its a bolt in deal although depending on design you may or may not need a new cable.
    Check out the billet assemblies Rex and others sell. The right hand foot pedal bolts to the assembly. Left foot pedal blanks are made, could very well be a bolt in deal.
    Unless you are going with a nice offshore style hand control, Id stay away from the hand throttle deal if at all possible. I've used one in the past and it left a bit to be desired.
    I realize you have some pain to contend with, but if the left leg is up to the task, Id go that route.
