top speed problem/question
Results 1 to 14 of 29
    Oct 2010
    LaPorte, Indiana
    Default top speed problem/question
    I have a 1975 sanger super jet. its 18ft long, 1700lbs with a 455 olds. I was told the engine was rebuilt last year and had 513hp. Today I only got a best top speed of 46mph on my gps. The engine seems to be running pretty good. The boat gets up on plane pretty fast and gets to 46 pretty fast, but then it stops. Is my boat just too heavy? Is that how fast those boats are? Or is it my drive? It just seems like it should be doing a lot better than that. any suggestions? thanks
    Wet
    Wet is offline
    East Hampton, CT
    What kind of RPM's are you turning?
    The Right Coast/SE-PA
    What RPM is the engine turning???
    A friend of mine had the same boat (very quick) and it pulled like a Bull to 65 mph with a 330 HP 454 (A) Imp >sorry I don't recall the RPM.
    Oct 2010
    LaPorte, Indiana
    I dont know, my tach is broken. I will try and get a tach. thanks
    Oct 2010
    LaPorte, Indiana
    do you think its my jet drive. ive got the 12jb-a? I have been wanting to rebuild it, but would that cause that much of a difference. consideration your friends boat as of right now is a lot faster than mine. I guess I just wanted to see if this was normal, I was expecting a little more out of her
    Nov 2008
    Fuquay-Varina, NC
    If the motor seems to be pulling strong chances are its the pump. My WJ12 is getting a rebuild this winter, it would only run 51mph at 5100RPM last year
    '77 Caribbean
    Oct 2010
    LaPorte, Indiana
    alright, looks like a pump rebuild is in the future for me. Thanks a lot for the help
    Quote Originally Posted by 173rdbrandon View Post
    Fix your tach FIRST, then take it out for a run and see what the motor is actually turning. You need this info before condemning the pump.
    And he said this to you with a totally straight face.
    Oct 2010
    LaPorte, Indiana
    reallyyyyy........ that bad huh
    Senior Member jorndy's Avatar
    Sep 2010
    Some Where Between lost and found
    Better hurry up with the tach and run it, another week and you will have ice on the water up there.
    That HP on a 455, not saying it can't be done but it may be a stock low HP engine > get the tach and report back with max RPM's .
    If it's infact an A imp, that will tell part of the story.
    No, not really. So long as the motor looks like the one on the cover of this book, was built by Joe Mondello, Dick Miller, or Warren Johnson. Then I am sure it does.
    Default Pump??
    Ah, no. As mentioned, fix the tach, and/or speedometer.. Or are you using a GPS?? Either way, if the pump "pulls hard" up to that point I doubt the low top speed is a pump issue... I have a very stock 455 that runs 57MPH, (down river), and quite frankly, there is something missing from this story??? More than likely your 513 HP is a bit of a fish tale.. However, I doubt mine is making any more than the original 330HP and does run 57 on GPS w/ an "A" impeller.... Something is fishy here....Maybe the boat has a huge hook in it??......Maybe the installed angle of the pump is way off? Maybe the ride plate, (if so equipped), is driving the nose in...??.....Something just doesn't sound right unless the engine is a total turd, but then it would be a turd down low as well???.... Fix the tach before you do anything..
    Ray
    LOUD BOATS SAVE LIVES
