Berkely 12jc Pump
Results 1 to 6 of 6
Berkely 12jc Pump
    Tabs Up Drives Out J-Bonz's Avatar
    Bay Village, OH & Johnson Creek, WI
    Default Berkely 12jc Pump
    Hey guys, Really dont know much between all the different pumps... Is a 12jc a good one to run? Whats the limitations with it? What speed range do they fit in?
    Thanks,
    Jr.
    Tabs up, Drives out................
    Senior Member gregb's Avatar
    Redondo
    JC is a fine pump. Most people like the JG pumps because you can add a wedge, droop, snoot, or extension. You can't do that with a JC. If you are not wanting to add that kind of stuff I don't think you would see any performance difference between the two.
    Southwest corner AR
    A JC is the same as a JA JB and a JG's only difference is the split bowl! Some say the JC bowl is a little better than a JG I think a little longer on the outlet side! WT
    WT
    WFL Crew!!!
    As said they are all basically the same the "limition" if any to the C bowl is the inability to "wedge" or install Berkeley "bolt ons " (droops etc) at the rear of the bowl Tom
    (C bowl is white here)
    Another dumb question..... So does that mean all the intakes for the A, B, C, & G are the same? Do some offer further set back?
    Thanks guys,
    Jr.
    Senior Member harley222's Avatar
    Sep 2009
    I have a JC im my sunkisst and i love it, it loads hard and works great for me, just need to add a place diverter and i will be very happy with it...
