proper plumbing
Results 1 to 14 of 14
proper plumbing
    Jun 2010
    Rangeley Maine, United States
    Default proper plumbing
    Im putting a blower motor in my jet boat ive got a good idea on the plumbing .not sure if someone has a diagram looked around here and dont see one .
    its a 468 bbc blower with a intercooler and a engine oil cooler .also have a pressure relief. 1 outlet off of berk jet .
    any help is appreciated thanks
    domenic
    Default cooling
    no pic but In from pump #10 to gate valve to pressure bypass valve to oil cooler to tee #8 to front engine block water pump inlets. one #10 over board discharge from ft ft of intake. Other is line to headers. One #10 from water bypass overboard side to intercooler out to overboard. Install a seperate pressure relief on inter cooler for safety. My system worked fine for this past yr. Good luck
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    I've seen quiet a few blown jets where they tapped the side of the bowl for a extra feed. I believe they feed the intercooler with it. Somebody here may chime in on this.
    Jun 2010
    thanks guys ill give it a shot
    Where you get the water for the inner cooler is irrelevant. Point is you want it to get zero water at idle, but not too much pressure from 2500 rpm up.
    Jun 2010
    so i need to get another pressure relief for intercooler
    what is min/ max pressure
    domenic
    Quote Originally Posted by bgblock View Post
    domenic
    Yes you do need another. I believe no more than 20 lbs. Mine's set at 18 psi on both.
    High Performance Marine ARS Marine's Avatar
    Feb 2009
    Morris,Illinois
    We did a setup for Tunneljet here on the boards and it seemed to work very well. Yes two bypass reliefs, one for the motor water pressure and the other for the intercooler pressure.
    Jun 2010
    ran off the hose today ran cool no leaks have a temporary setup.
    wanted to hit the lake but to late . I can test it out with out hooking up intercooler ? i got to get another pressure relief valve for it and prolly wont have it here before the weekend and i got too try her out supposed to hit maybe 60 wow friggen heat wave . thanks for the help guys
    domenic
    Jun 2010
    so ran on hose today ran good water coming out by pass even on the garden hose . i dont have the intercooler hooked up yet so i just overboarded the bypass had water comming out of bypass at the lake even at idle then i lost all pressure comming out of pump for cooling and eng got hot Am i missing something ?? tomorrow im wearing waders and going to leave on the trailer and run it and see what comes out of pump for cooling . All was fine till i thought i lost oil pressure went back to shop for a mechanical gauge oil pressure fine gauge was lying so then i go for a ride and io cant keep it cool . At least oil pressure fine
    its an new pressure relief from htp . what pressure should i see out of pump for cooling
    domenic
    Shell Knob, MO
    If I read your post right, you had water coming out of the bypass at idle. If so, that is not right. There should not be anything coming out at idle. The fact that it is and that you are having heating issues would cause me to look for something stuck in the bypass or pump somewhere. If you don't find the problem, give me a call.
    Duane HTP
    Jun 2010
    check valve not set going to go get a gauge and set it. also fitting out of pump had an allen screw restrictor in it i changed fitting to a non restricting cya going to lake bout 10 people should be awake and ready for some noise domenic
    Jun 2010
    got cooling resolved pressure reducer sorta set prolly not at 15 got to talk to duanne on procedure to set it . rpms max 6k saw like 80 mph
    ready to push a little more do blowers rattle at low idle ? also seems to leak a little bit round front and rear covers ? got a little water leak back of boat got to get that squared away and jetaway leaks a little got to work on that a bit at least fill it for now maybe get up to 90 this week weather permittin we are gettin chilly round here . no snow for the next season of snowmobiling yet so got to keep boatin
    domenic
    Jun 2010
    ttt??
