Wiring Questions
Results 1 to 9 of 9
Wiring Questions
    Senior Member 76 Bonneville's Avatar
    Valley Center Ca
    Default Wiring Questions
    Need help with wiring the gauges. What are the proper color wire to use? Heres the dash layout from left to right, ignition, kill button, bilge, oil temp, oil pressure, tach, water temp and fuel. Has a mag now but would wire for a future elec. tach and no alt. yet but a volt gauge could go in a pod on the motor with a fuel pressure gauge.
    Wet
    Wet is offline
    East Hampton, CT
    Standard Marine Wire Code Table
    Red Constant Hot
    Black Ground
    Purple Key-on Power
    Yellow/Red Neutral Safety
    Tan Water Temperature
    Dark Blue Gauge Lighting
    Pink Fuel Sender
    Gray Tachometer
    Light Blue Oil Pressure
    Brown/White Trim Indicator
    Brown Bilge Pump
    Green/White Trim Down
    Blue/White Trim Up
    Green/Orange Independent Tilt Down
    Blue/Orange Independent Tilt Up
    Yellow/Black Choke Circuit
    Yellow/Red Starting Circuit
    Black/Yellow Ignition Cut-
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    Quote Originally Posted by 76 Bonneville View Post
    Try this.
    Valley Center Ca
    Thanks, both of those really help. I hate wiring, not looking forward to laying on my back, fumbling around with those connectors and nuts and washers. Maybe I can talk my son in to doing it for me.
    Sacramento, CA, USA
    The one thing missing in the drawing is for the fuel gauge and that wire is suppose to be pink. I've got to do the same thing and I did a temporary wire job to get the motor started and it won't be too bad.
    Here's my wiring at the back of the motor, in the very bottom center of the photo:
    My dash front:
    Gauges from behind:
    I hate to have to make the brackets fit the gauges t hold them to the dash.
    Darn, I just noticed, I've got the hook up the steering too.
    Sacramento, CA, USA
    I need to find out how to use the thumbnails when I want to show photos. I'm a
    Why? The way you are doing it is the better way as the pics show up full size. No need for people to click on thumbnails to see the full size pic.
    Sacramento, CA, USA
    I just thought that's the way people liked things... Double clicking gives them something to do.
    Lexington, KY
    No I hate clicking on the thumbnails! The pictures are a lower resolution too, until you click on them again. Then they open up again with the full sized image. Very annoying. Keep doing it how you're doing it, please. Got enough to do reading all the posts and responding to some of them.
